engine swap/ conversion ideas
Old Dec 18, 2010 | 07:25 PM
monstr250's Avatar
so i'm in the middle of buying a house right now so i'll have a fresh empty garage to get some work done in and was thinking about changing my rig up a little. not sure what i want to do just looking for possible ideas. what kind of engine swaps have you guys done? body swaps? 2wd to 4wd?
Old Dec 18, 2010 | 08:15 PM
Douglas2's Avatar
After seeing the 1980, 4-headlight variant I want one of them. May take radical surgery but it would sure light my way...Li-i-i-i-ght my way...sorry, Terrapin Station derailment...
cheers,
Douglas
Old Dec 18, 2010 | 09:04 PM
TIMMY22's Avatar
I did a gas W250 to a cummins. It was fun, I like the ramcharger idea too.
Old Dec 18, 2010 | 10:22 PM
dieseldawg604's Avatar
i did a 1984 gmc wrangler to cummins swap
super simple!! and worked out great!
Old Dec 19, 2010 | 07:46 AM
Trebor's Avatar
I'm in the middle of doing a short bed crew cab gasser Dodge V8 automatic 2WD to a Cummins powered NV4500 5 speed 4WD repower. It's involves taking 3 trucks and making one. It IS a lot of work doing this 2WD gasser to 4WD diesel route.
Old Dec 19, 2010 | 09:39 AM
MiniC's Avatar
Im in the middle of putting a Cummins in a 1968 swb Chevy pickup. When its all said and done will be close to 2000lbs lighter then the donor, needless to say Im excited about the mileage!!
Old Dec 19, 2010 | 12:08 PM
monstr250's Avatar
i really like 4wds better than 2wds. i like the pic of that gmc swap. is that all dodge drivetrain and a gmc body or are there adapters that can be used to just do an engine swap? since i dont have a 4wd drivetrain it would be nice to just get an adapter to butt up to a ford or chevy. i like the dodge but they are way harder to find in good shape.
Old Dec 19, 2010 | 12:52 PM
the gmc is mostly dodge! its got a getrag and 205 tc
the axles are from an old logging crummy dana 60hd and dana 70hd
its got a polished aluminum freightliner fuel tank in the box
and we used a crossmember from avalanche engineering made the swap easy!! used the stock gmc trans crossmember un molested!!
Old Dec 19, 2010 | 09:45 PM
jimlj's Avatar
I put a '89 CTD in my '79 F250. I used the engine and transmission (NV4500) from the Dodge, an Advance Adapters adapter to go from the NV4500 to the Ford NP205 transfercase. I had a rear driveline built, and was able to use the front driveline from my '79 F350 axle donor. I used the Dodge motor mounts on pearches I built myself. I rebuilt/modified the Ford transmission mount.
Old Dec 20, 2010 | 09:21 AM
monstr250's Avatar
did you have any problems with suspension not being strong enough for the added weight of the cummins?
Old Dec 20, 2010 | 09:35 AM
92smokin blacky's Avatar
we need pictures! I love that year of fords, thats one of my dream swaps I'll do someday
Old Dec 20, 2010 | 07:40 PM
the wrangler is a one ton and it had no problem at all!
SHARPMACHINE
Cummins Conversions
Dec 1, 2010 09:12 PM
YOUNG GUNS15
Cummins Conversions
54
Oct 20, 2010 08:21 PM
SWATPARAMEDIC
Oct 19, 2009 03:25 PM
racinrex
Sep 30, 2005 02:47 PM
dsljunkie
Jan 14, 2004 10:46 AM
