engine surging when cold
Old Feb 25, 2008 | 09:13 AM
Dwitt0187's Avatar
Question engine surging when cold
2 weeks ago i modded my fca. the truck ran fine after doing it and then the next day the truck started fine when i pulled out on the road the truck would surge if i push the throttle a little to fast and once it warms up truck runs great. the fca was is great working order when i put it back together. could this be a regulator problem? fuel pressure at pump is around 27lbs at idle and 20 wot. does anyone have any idea what would cause this.
Old Feb 25, 2008 | 09:55 AM
Dwitt0187's Avatar
bump try agian???
Old Feb 25, 2008 | 07:20 PM
Dwitt0187's Avatar
am i the only person that has this problem???
Old Feb 26, 2008 | 12:59 AM
drewblood's Avatar
no you probably need to polish the fca its more thn likley hanging in the bore
Old Feb 26, 2008 | 04:42 PM
Dwitt0187's Avatar
what is the best way to polish the fca i used 220 grit sand paper is that to rough ?????
Old Feb 27, 2008 | 02:57 AM
drewblood's Avatar
not sure but i used 320 then 600 grit and its good
ocsurf16
Jan 25, 2007 10:33 PM
cutlass
Oct 15, 2005 12:48 PM
torqueman
Sep 1, 2005 10:01 PM
APD
Mar 3, 2005 05:39 PM
ChrisM55
Oct 19, 2004 02:56 AM
