Engine Squeek at shut down
Old Aug 7, 2004 | 05:28 PM
Sweeper54's Avatar
I've read the Aug 03 posting of this question, but I'm still concerned about this very loud squeek on shut down when the truck is at operating temp. I use a cool down timer and don't get the squeek when I have to use the truck for a short trip when the truck doesn't fully reach operating temp.
Old Aug 7, 2004 | 06:22 PM
kayjh's Avatar
There is a bulletin. It's a normal noise.
Old Aug 7, 2004 | 06:27 PM
phox_mulder's Avatar
You'll find it getting more and more random as you put some miles on the truck.
New, I'm pretty sure it did it every time.
I don't remember it doing it much at all during this last winter, maybe every 6th or 7th shutdown,
and now it seems like every 3rd shutdown.
A lot depends on if I use the A/C, and for how long.
How long before shutdown did I turn the A/C off, if even.
phox
Old Aug 7, 2004 | 06:37 PM
Sweeper54's Avatar
I've got 15k+ on it, with about 1k towing an 11k lbs trailer and I rarely use the A/C.
Old Aug 7, 2004 | 07:06 PM
Fummins's Avatar
Re: Engine Squeek at shut down
Are you referring to the belt "chirp"?If so,this is normal,but can be rectified with a Goodyear gatorback replacement belt.
Old Aug 7, 2004 | 07:12 PM
bulabula's Avatar
That shutdown squeek is normal; the easiest thing to do is just ignore it - another option is to never shut it down.
I smile when mine does it - lets people know there isn't 1.8L buzz bomb under the hood.
Old Aug 7, 2004 | 08:02 PM
Jeff in TD's Avatar
The Cummins in the Freightliner at a farm where I once worked made the exact same sound (only on a bigger scale).
I think my truck only does it if the fan clutch is engaged when I shut it off... (fan appears to run even if coolant isn't hot if the AC is on, apparenlty to pull air into the condenser).
I wouldn't worry about it. The thing has 6 big, high compression pistons, and the crank accelerates and decelerates a couple of times as a few pistons hit compression stroke before things comes to a stop, and it just chirps the fan belt...
04 Diesel
35
Sep 8, 2009 08:43 PM
cbrahs
Jun 7, 2007 10:42 AM
drew03
39
Nov 13, 2005 09:20 AM
Txwelder
Jun 3, 2005 07:34 PM
Ken W
Jul 23, 2004 05:24 PM
