Engine quit. Code 0628
Old Mar 23, 2005 | 11:51 AM
Raspy's Avatar
From: Smith Valley, NV (sometimes Redwood City, CA)
Engine quit on the freeway. For a few seconds it just got weaker but then it shut off and I coasted to a stop. After cranking it a few times, for about two seconds each time, it started and ran fine for about a mile. Same thing with the cranking and it re-started again. I was able to coax it home with several more re-starts.
It was raining very hard and there were lots of puddles.
I turned the key off and on several times to get a code of P0628. Fuel Pump "A" Control Circuit Low. I don't know what that means. Voltage, pressure, or what?
Thanks for any help.
Wetspirit
Old Mar 23, 2005 | 12:25 PM
infidel's Avatar
Not knowing '04 codes and the fact that it was wet out my bet is one of the pump connectors is shorting out on water. Nothing a little compressed air and di-electric grease won't fix.
Old Mar 23, 2005 | 12:33 PM
67HotRod's Avatar
I would have to agree with infidel.
Old Mar 23, 2005 | 12:47 PM
Raspy's Avatar
Those are both good guesses and they match my guess exactly. But simply looking for wet wires in the rain is not much help. I can't fix a wet connection till I have an idea where it might be or even if it is a wet connection. What I need is someone familiar with the '04 codes that can define the term "Fuel Pump A Control Circuit Low".
Thanks, Wetspirit
Bone
May 3, 2010 10:16 AM
dougnbse
Jan 30, 2009 10:14 AM
Cozy Heat
Aug 14, 2007 01:39 PM
Hondo
Apr 19, 2007 01:23 PM
mattk50
Apr 17, 2006 10:00 AM
