engine osolating
Old Jan 27, 2009 | 12:15 PM
louddodge's Avatar
engine osolating
Anyone know what my cause an engine to osolate while idling? The only time I notice it is at idle and the interior lights dim at the same pace.
Old Jan 27, 2009 | 12:36 PM
John Faughn's Avatar
Sounds like the grid heaters are cycling , because you mentioned idling & interior lights dimming .
Does it happen warm / cold ?
How much RPM change ?
Old Jan 27, 2009 | 12:43 PM
04ctd's Avatar
the grid heaters will dim the lights,
and if its REAL cold the truck will idle itself up to protect itself.
i usually run the High Idle on my 06 if it's cold, to keep the voltage flowing and warm the motor.
Old Jan 27, 2009 | 12:59 PM
El Borrego's Avatar
Engine osolating
If it happens right after you crank it up it's natural. What is happening is the power drain from the fuel heater and the starter is causing your alternator to rebuild the battery strength to normal. If it does this all the time it may be your alternator or voltage control.
Old Jan 27, 2009 | 01:00 PM
GasganoFJ60's Avatar
Pull the pin up.
When my fan oscillates I pull the pin up to make it stop. Try that.
But yeah, its probably your grid heaters cycling cause of the cold weather. Itll do that for the first few min of a COLD start.
Old Jan 28, 2009 | 11:43 AM
louddodge's Avatar
It does it even after the truck has warmed up. I can tell when the grid heater cycling. There is not a drop on the tach but you can hear it in the exhaust and it follows the lights dimming. They are in time with each other.
Old Jan 28, 2009 | 10:26 PM
mini14's Avatar
ive had that happen to me too but only when its real cold and high idleing, its not the grids cycling, i dont know what it is either. its pretty noticable.I pay it no mind. when cold diesels do some strange things. maybe its engine shrinkage.
Old Jan 28, 2009 | 11:00 PM
trksrfun's Avatar
Originally Posted by GasganoFJ60
Pull the pin up.
HAHA
but yeah most likely just the grid heaters like others have said
Old Jan 28, 2009 | 11:22 PM
cbrahs's Avatar
read this guys.
the grid heater will cycle even if your engine is at full temp! It is activated by the intake air temp sensor. If it is cold out it will come on
https://www.dieseltruckresource.com/...ater+operation
Old Jan 29, 2009 | 12:15 AM
Kowalski's Avatar
Do you by chance have it set to defrost? When you have it set to defrost the AC compresor will cycle on and off putting extra load on engine. Mine will make the engine alittle louder but havent noticed lights dim though.
Old Feb 6, 2009 | 02:57 PM
louddodge's Avatar
It is alot faster than an A/C compressor or the grid heater cycling.
Old Feb 7, 2009 | 09:42 PM
louddodge's Avatar
I guess that the problaem is more like a lope than anything else. Have started to notice it going down the road now. I am wondering if it is something electrical. It is like there are electrical surges.
Old Mar 4, 2009 | 12:35 PM
13ALPHA's Avatar
Did you get this fixed? I know I have a VP but just noticed a similar problem, more frequent cycles than grids, but a little faster than a lope, and only when I let off and it's in neutral, like at a stop sign. I would say its like as if you just barely touch the pedal, every 1 second.
alltimelow1
Apr 6, 2005 07:28 PM
Stevenc
Dec 28, 2004 08:29 PM
apache
Feb 22, 2004 05:27 PM
