Engine Noises
Old Oct 4, 2005 | 07:50 PM
stonewalldiesel's Avatar
Engine Noises
Hey Guys, i have a question regarding my beast. I currently have all my mods off due to a bad VP44 Warranty Issue. I started hearing a pinging sound a couple of months ago before I removed my mods. It's coming from the head I'm sure. I checked the valve clearance and everything was bang on. So I new I had a VP problem so I removed my injectors and put in originals and removed the rest of my mods. I then took it to dealership for VP replacement. I told them about the engine noise and they are telling me they can't hear any abnormal noise, but did they go with me for a drive so I could point it out to them nooooo. Any way it sounds like a bad valve. but it only happens at low RPM. thanks
Old Oct 4, 2005 | 08:30 PM
More info that may help. I found the noise to be more evident when the engine warms up. It's very hard to describe but it sounds like a bad lifter in a gas engine. I'm going to check the rods tomorrow to see if any are bent.
Old Oct 5, 2005 | 02:38 PM
CTD NUT's Avatar
Any luck? When was the last time the valve lash was checked or adjusted?
Old Oct 5, 2005 | 06:24 PM
Hey CTD, I'm gonna check the push rods tomorrow. The valaves were checked by Cummins about 2 weeks ago, That costed me $250.00 for nothing as I set the valves about a MONTH AGO and they really wer not out that much. Cummins told me they were gonna go through the top end when I took it to them but all they did was check the valves I was not impressed as I told them I had checked that already. We'll see what I can find tomorrow.
Old Oct 5, 2005 | 09:47 PM
storx's Avatar
when you run bigger injectors the motor creates a pinging noise from all the raw fuel at idle.......... if you go to the sled pulls you will here theres are really loud almost sounds like a rod knock.....im not sure if it is bad for the motor or not but thats what i know its from
Mattster
Sep 6, 2007 07:59 PM
Hummin Cummins
18
Feb 12, 2004 03:28 PM
wood_n_soldier
Dec 9, 2003 10:36 AM
supercharger
Dec 7, 2003 01:04 AM
calvic
Apr 8, 2003 07:19 PM
