engine light on
engine light on
engine light came on and found code p0607 ecm internal failure.is this a dealer item repair. tried to reset code with no luck. any help on this much appreciated. thanks
Cummins Guru
Symptom:
P0607-ECM INTERNAL FAILURE
When Monitored and Set Condition:
When Monitored: With the key on or engine running.
Set Condition: ECM had detected internal failures.
POSSIBLE CAUSES
ECM
TEST ACTION APPLICABILITY
1 Turn the ignition on.
NOTE: This DTC is caused by an internal Engine Control Module failure.
Repairs are not possible to the ECM.
Is the DTC P0606 set?
ENGINE- 5.9L
CUMMINS 24V
DIESEL
Yes ! Replace and program the ECM in accordance with the Service
Information.
POSSIBLE CAUSES
ECM
ENGINE- 5.9L
CUMMINS 24V
DIESEL
Information.
stratos201proxl
01-16-2014 11:04 AM
Joey-D
12-12-2011 12:52 PM
choppers555
10-16-2007 12:29 PM
Stevenc
12-28-2004 08:29 PM
