Engine flutter
Engine flutter
Yesterday I was getting on the interstate. My engine fluttered then lost about 7 PSI boost and obviously lost some power. I let up and hit the throttle a couple of times and it picked up and went like nothing ever happened. When I got home the engine would not shut off with the key.
I pulled the shut down solenoid and found the little rubber plunger had a chunk missing on the end that seats down in the pump. I installed a new one and Im good to go.
It just kind of worries me as to where that piece of rubber went.
I have put about 80 miles on since it happened so I hope Im OK.
If you don't have any problems now, I wouldn't worry about it -- I would guess that rubber is floating around in very small pieces in your tank right now. It must have gone through the distributor pump, the delivery valves, and out to an injector, where it either got burned up in a cylinder (having passed through those fire nozzles you call injectors), or sent back to the tank in the return.
Luckily it shouldn't be abrasive at all, and is much softer than any of those components
I wouldn't have bothered with a new plunger, though, I'm a big fan of the hand cable
. I wouldn't have bothered with a new plunger, though, I'm a big fan of the hand cable
Thanks for your input guys, I am thinking after about 200 miles now that I will be OK.
asilitch, you said (having passed through those fire nozzles you call injectors)
Im not sure who your talking to, I dont call whats in my truck injectors, they are nozzles, everyone askes me why I call them nozzles, and I say "because they are nozzles"
it seems most on this sight call them injectors but not me.
Just setting the record straight
Im not sure who your talking to, I dont call whats in my truck injectors, they are nozzles, everyone askes me why I call them nozzles, and I say "because they are nozzles"it seems most on this sight call them injectors but not me.
Yup, me and Monty did kick this cat a bit... don't worry about it...and no the rubber isn't gonna go thru a nozzle tip.... we're talking really tiny holes here guys...well, you know what I mean..
PB..
PB..
Oh my -- I was just making a crack about your liking to pour the fuel into your engine through as large an orifice as possible.
But now that you all have me going: An engine is any complicated piece of machinery, and a motor is something that converts stored energy into mechanical power. Injectors have nozzles, but the nozzle is only the itty bitty part at the end with the holes, exclusive of the injector body and pop-off valve, etc.
OK, now that we have that all cleared up
I was quite sure that piece of rubber did not go through a nozzle. but I cant imagine where it is, It seems too big to go through a fuel return line too. OH well, it is gone, out of sight out of mind.
kertoncol
Oct 12, 2003 03:04 PM
