PDA
View Full Version : engine cuts out under load
gdlukn
02-27-2006, 12:15 PM
02 cummins.6 speed.. have replaced apps twice... have hypertech module and 5 in,. exhaust.. runs good without trailer...new fuel filter & replacesd electric pump on side of block. engine surges or cuts out under a load... any suggestions appreciated 168,000 miles
dieselrob
02-27-2006, 02:53 PM
Do you have gauges? They help answer most question. Did you check for any codes. Turn key on, off,on, off, on and leave it in the on position. Try that. You might have vp44 troubles.
mini14
02-27-2006, 09:04 PM
check codes but sounds like a low boost/map sensor problem possibly if it only happens under a load. could be other problems but first check for codes
