Engine codes
Old 11-27-2003, 03:58 PM
Kimrey's Avatar
Engine codes
All this talk of engine codes latley got me to looking at my rig. I went and used the ignition to get the codes and now I'm confused. :-[ Here are the codes 0500, No VSS signal, 1693, DTC detected in companion module or DTC detected in PCM/ECM and 0234, Turbo Boost exceeded.
Now I can probably see the 0234 but I have a boost fooler. The other codes I'm confused, what do they mean and what is wrong? Any help is appreciated!!
Thanks, Kimrey
Old 11-27-2003, 08:50 PM
billg's Avatar
Re:Engine codes
Take a look here:
http://www.troublecodes.net/chrysler/
Old 11-30-2003, 06:20 PM
Kimrey's Avatar
Re:Engine codes
Billg, I did, that's where I found what the codes said, but what do they mean? What's wrong with my truck, what can I do to correct that? Thanks for the response, I thought there were more people out there that knew what all this meant?
Kimrey
Old 11-30-2003, 06:51 PM
DF5152's Avatar
Re:Engine codes
0500 no speed sensor signal....does ur cruise control work and ABS
the DTC code seems like it is just telling u that there is a code that wasnt expected because everything seems to be working properly
also if u have no check engine light these could be history codes...
Old 12-01-2003, 11:59 AM
Kimrey's Avatar
Re:Engine codes
DTF5152, So there is nonthing to worrie about, right? Cruise works great, ABS, I guess it works. Haven't had to use it lately . I did replace my brake fluid a while back. As far as the other DTC codes, there is no worrie right? If you have any more ideas let me know. Thanks for the help!
Kimrey
Old 12-01-2003, 12:24 PM
Kimrey's Avatar
Re:Engine codes
Jack, I haven't. I thought once the codes were there, they would stay until you reset the computer. I was understanding that you can un-hook the batteries for 20 minutes and it would reset the computer. I will try that over the next few days. Thanks,
Kimrey
Old 12-01-2003, 12:34 PM
billg's Avatar
Re:Engine codes
Some codes clear that way and some clear after several starts without the condition that caused the code. Others will have to be reset by a code reader. If you know someone with a supperchips programmer they can read and reset them for you. You can also go to some auto part stores (Advanced Auto, Auto Zone) They will sometimes read and reset the codes for free.
Hope this helps.
Old 12-01-2003, 02:42 PM
Willyzao's Avatar
Re:Engine codes
[quote author=Kimrey link=board=4;threadid=22934;start=0#msg214991 date=1069970305]
Thanks, Kimrey
[/quote]
I have had the same codes that you listed. 0500 I got from spinning the tires too much (driven on ice or snow lately?), 1693 is a companion code that doesn't mean anything other than there is another code set, and 0234 is the overboost. My EZ wasn't hiding the boost, so I sent it back and they sent me a new one and I haven't had a problem since.
Old 12-01-2003, 02:56 PM
Kimrey's Avatar
Re:Engine codes
willyzao, Maybey when it rained last time My van-akken box did not come with a boost fooler. I bought it seperate. It's a small box about the size of a small box of matches, and plugged it in the harness. The truck still has power above 20# of boost. I thought if the computer read over boost it wouldn't fuel anything above 20#? Now I'm really confused. So with the boost fooler it's not supposed to throw a code?
Thanks, Kimrey
Old 12-01-2003, 04:59 PM
crobtex's Avatar
Re:Engine codes
I've lost my instructions for the ignition code test. :'(
Could someone please point to the thread.
Thks,
CR
Old 12-01-2003, 06:40 PM
Kimrey's Avatar
Re:Engine codes
All I do is turn the ignition on three times ( Don't bump the starter ) and look at the odometer display and it show you the codes.
Kimrey
Old 12-02-2003, 09:57 AM
Willyzao's Avatar
Re:Engine codes
[quote author=Kimrey link=board=4;threadid=22934;start=0#msg216554 date=1070312199]
Thanks, Kimrey
[/quote]
I take it you have an older VA, I think the new ones come with a boost fooler built in. Any boost pressure over a certain psi (19 or 21) is intercepted and 'chopped' by the fooler so the truck's computer only sees normal boost numbers. You probably won't notice much of a difference unless you pay close attention to how the truck responds after you clear the code. This thread will explain it better: http://www.turbodieselregister.com/f...threadid=86752
My EZ wasn't fooling anything, so I sent it back, they sent me a new one and I cleared the code; the difference was amazing. Just make sure you clear the code before any warranty work is done, that's an automatic red flag at the dealer. I've heard the 0500 will clear itself, so spin away .
Old 12-02-2003, 09:16 PM
highmtnjeepn's Avatar
Re:Engine codes
Willyzao-
You say 1693 is a companion code? It's the only one my truck is showing, so I don't think I have any others set...
I've got another thread going -what's up with my truck.
Any ideas?
Sorry to hijack the thread, but I need this truck for work.
Thanks, AUstin
Quick Reply: Engine codes
