Engine code P0273 Turbo Boost Sensor
Old Mar 24, 2006 | 05:30 PM
Pinkston's Avatar
At lunch when I got in my truck the check engine light was on and it was running like a dog. Got the code read at auto zone and came up with P0273. He said it was a bad turbo boost sensor. After checking with the *********** to see if they have it I got in the truck and it was running fine. The light is still on because I have not cleared the computer. I tried searching, but the search seems screwed up tonight. Any ideas on this? Has this happened to anyone before?
Old Mar 24, 2006 | 05:43 PM
Bob Wagner's Avatar
are you sure that is the correct code? its not even listed that I can see
Old Mar 24, 2006 | 05:52 PM
Pinkston's Avatar
Im almost positive thats the code. I wrote it down straght from the code reader. Is there another code for the turbo boost sensor?
Edit, I could have written it down wrong, the code may be P0237 if that helps.
Old Mar 24, 2006 | 06:00 PM
Bob Wagner's Avatar
Po237 map sensor voltage too low
don t worry about it, sensors do go bad.
Old Mar 24, 2006 | 07:25 PM
Pinkston's Avatar
Thats kinda what I was thinking. Just making sure it wasnt anything more serious. Hopefully I can pick one up in the morning.
Old Mar 25, 2006 | 07:08 PM
ib516's Avatar
Next time you get the engine light on, no need to get codes scanned at parts store. Just cycle the key on/off/on/off/on (do not start engine), and the codes will show up in odometer.
Old Mar 27, 2006 | 08:13 PM
Pinkston's Avatar
Thanks for the tip.
I just changed the sensor with one thats used, but I know its good. I also had the code cleared by a buddy that works at a shop with a code reader. It was fine for about 5 miles and the the check engine light came back on and started running like *** again. It seems to come and go, one minute it runs fine the next its not getting any boost.
any other ideas?
could this have anything to do with the boost fooler on the truck? can they go bad?
By the way, I just went out and checked the code and got P1693.
Old Mar 29, 2006 | 07:36 PM
Pinkston's Avatar
Well I unhooked the boost fooler and it seems to be running fine. Now i deen to get the code cleared and see if it comes back. Where is the best place to get a boost fooler?
Old Apr 4, 2006 | 08:54 PM
WSA308's Avatar
Boost sensor code
Was just told mine was bad code P0122.
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Marks99
0
Aug 23, 2006 06:24 PM
Booost Almighty
Jan 1, 2006 01:41 PM
wildmann
Aug 14, 2005 07:15 PM
