Engine Casting
Old Aug 18, 2005 | 11:11 AM
G-NOTE's Avatar
Engine Casting
I have a 55 casting, on the block...
GOOD or BAD????
Old Aug 18, 2005 | 11:34 AM
CTD NUT's Avatar
55 is good.....there have been some documented cases of them cracking in the same spot as the 53 but that appears to be an extremely rare occurrence. The risk is negledgable.
Old Aug 18, 2005 | 11:43 AM
G-NOTE's Avatar
So whats the best 56 ???
Old Aug 18, 2005 | 12:19 PM
CTD NUT's Avatar
I'm not really aware of casting that is better than the others.....no specifics I'm aware that makes one casting superior.
Old Aug 19, 2005 | 04:58 PM
G-NOTE's Avatar
So I'm good to go w/ a 55 ? ? ?
Old Aug 19, 2005 | 06:48 PM
jrs_dodge_diesel's Avatar
Yep. 55 is good. The 53 is the one to avoid. It has the thinnest block casting and is prone to cracking. This was changed and the block was thickened in the 54 series and up. The blocks with the casting numbers were made by a Brazilion company called Tupy. There is also a Mexican company that casts them as well by a company called Teksid. Thier blocks are the beefiest around.
Click here for more info.
Old Aug 19, 2005 | 06:52 PM
HOHN's Avatar
FWIW, I've heard that the Teksid blocks are stronger. These are the Mexican blocks. They can be identified by the LACK of a 53, 54, 55, etc onthe block near the pan rail. Instead, they just have a series of small numbers....
This was originally posted by Pit Bull on TDR:
"1. Brazilian Blocks are cast by a company named "TUPY" and are marked such.
They are identified with cast evolution numbers.
#53's are TUPY's. #54 and later evolutions were improved to correct the block issues that the 53's had.
2.Mexican Blocks were made by "Teksid" these blocks to my knowledge never had a problem with cracking, as they are heavier duty by trait, but they did follow the evolutions and got thicker.
These blocks do not have the 2 digit "cast number" embossed on the side, instead a series of numbers that are unidentifiable to me.
The mexicans blocks were rumored to even be harder to machine do to a harder cast overall, basically better quality in my opinion.
Brazilian Tupys always seem to outnumber Mexican blocks during the ISB's production probably about 8 to 1.
So basically if there is a pattern number its brazilian, if there is a series of small numbers its mexican.
By the way the Mexican equivalent of a 56 pattern was the Heaviest ISB block of all.
I had a 2000 that had a Mexican block. I looked and looked for a pattern number and all I could find were the smaller series of numbers. When I bought my 2002 and checked the #56 inch high is very easy to see. If you don't see a #53,54,55,56 and only find a series of smaller around 1/2 numbers that are hard to makeout then you have a Mexican block."
Guess which one I have? MEXICAN "56" BABY
Old Aug 19, 2005 | 06:55 PM
GlennRMK's Avatar
I have the Mexican block on mine.
53 is bad. Some crack, some don't.
54, 55, 56 are all highly unlikely to crack
Old Aug 22, 2005 | 07:31 AM
G-NOTE's Avatar
Thanks for the help, bought a "55" block...
Old Aug 22, 2005 | 08:49 AM
Buckshotmckee's Avatar
They say "56" is the big boy.
Old Aug 22, 2005 | 09:26 AM
storx's Avatar
oh that really blows i crawled under there to look last night and it says 53 gah.........blasted number.....where does it normally crack?......
Old Aug 22, 2005 | 09:46 AM
Supermod56's Avatar
On the right side near the heat exchanger, oil cooler, whatever that thing is. Between cylinders 3-4 (I think) From what I have read the more you bomb it the more chance of it cracking due to higher cylinder pressures, but some guys have had no problems.
Tom
blh1960
23
Dec 31, 2004 12:35 PM
v8440
Oct 21, 2004 01:39 PM
Haulin_in_Dixie
Apr 3, 2004 01:47 AM
RedWhiteDiesel
Mar 8, 2004 09:44 PM
tool
Dec 27, 2003 02:27 PM
