Energy Suspension Motor Mount Inserts
Old Mar 30, 2010 | 08:27 PM
Astro's Avatar
I was flipping through a new Diesel mag while on the throne and saw that Energy Suspension was advertising their new Motor Mount Inserts for 94+ Dodge Cummins. Just curious if anyone has used them and what you have to say about them? Can you install them with the motor in place? I've used motor mount inserts on other vehicle with good results, but with a rattling Cummins, I'm concerned with excessive chassis shake. Any feedback?
Energy Suspension Part #5.1114 , lists for around $40.
Old Mar 30, 2010 | 09:10 PM
Escursion12V's Avatar
I installed a set in a stock set of mounts that I will be using in my conversion. They push in around the stock rubber. Fills in the open areas. The mount will have to be up out of the frame bracket to install.
Randy
Old Mar 30, 2010 | 09:32 PM
Astro's Avatar
Yeah, I've used these mount inserts on other vehicles I've had, just not a Cummins-powered Dodge. They always worked well in the other cars, but like I said, I'm just concerned about the shaking Cummins and how it will transmit through to the frame & cab.
Old Mar 30, 2010 | 09:41 PM
I would think it will stiffen it up some. I am using them because my stock rubber is cracked. Will probly be 3-4 weeks before I find out how they work.
Randy
Captain
Oct 30, 2008 08:46 PM
Hammily
Jul 9, 2008 09:34 AM
nvr-enuf
Nov 7, 2007 02:09 PM
MKELLY
May 28, 2005 06:35 AM
