What else should I do?
Old 12-17-2008, 01:01 PM
rock crawler's Avatar
I am about to start my AD150 install on Thursday. I plan on doing the vent mod and the stock filter delete bracket. What else should be done while I have the bed off?
BTW, I've got all my parts and slowly getting them installed. Man, I want to drive my truck so bad.
Done: turbo, exhaust manifold, intake horn, exhaust, MP-8, S&B intake
Almost done: Isspro Performax gauges
Not done: AD150, vent mod, filter delete bracket, CP3 mod, injectors, trans. parts
Old 12-17-2008, 01:20 PM
rogers259's Avatar
If you've got the parts for the CP3 mod I'd do that at the same time.
Also try and lay everything out and take care of as much stuff ahead of time before you actually crack the fuel lines. Mount the pump, route the lines, route the wiring harness, etc. That way if you get into it and find you missed or forgot something you still have options if you need to make a run to the store. Yeah I learned that the hard way and the wife was on night shift at the hospital.
Also, When you run the new vent connect it to the old vent location on the filler neck. I know this sounds logical(stupid me) but for some reason I wasnt thinking at 4am and ran that vent line to that silver splice in piece. If you are planning on modding the fuel canister and putting the draw straw and return into the canister you won't need that silver splice in piece. Leave your filler neck line alone. Since I goofed and spliced it in and ran the vent to it whenever I go to fillup it foams bad and does not vent properly...worse than stock!
Have fun and refer to 53 ******* post and you should get through it w/o any problems.
Lost Lake
01-07-2011 06:57 PM
marlbroman
13
09-07-2008 02:25 PM
spitfire9137
07-14-2008 07:18 PM
Checkmate
03-02-2008 12:50 PM
LanceD
02-06-2008 05:28 AM
Quick Reply: What else should I do?
