electrical problem
Old Oct 27, 2009 | 07:26 PM
POSracer15x's Avatar
electrical problem
I have a '91 1/2, 3/4 ton that I am having an issue with. Took the truck to shop to have brakes worked on and ended up having to replace the starter. The mechanics claim something shorted out in the fuse box, and now my windows dont work or a/c and heater. When I hit the window button the wait to start and water in fuel lights come one and stay on as long as my finger is on the button. Same thing happens with the ac and heater. There are no blown fuses in the box or any other electrical problems. Has anyone else had this problem and if so what did u do to fix it?
Thanks, Sean
Old Oct 27, 2009 | 07:54 PM
Jim Lane's Avatar
Thanks, Sean
Pull down the fuse panel and look at the backside of it and see if any of the connections have burned where the wires are connected.
Also look for burned fuse links in the harness between the battery and firewall and loose ground connections.
Old Oct 27, 2009 | 10:19 PM
Tron's Avatar
I would guess a bad ground. I thought there was some one on here a few years back that had a similar problem. Try a search, you may get lucky.
Old Oct 28, 2009 | 05:59 PM
Ground issues is the most likely problem. The main body ground is on the core support just in front of the battery.
Also look at the fusible links on the fenderwell near the battery. Crispy = bad.
bigredbrick
May 1, 2003 11:59 PM
feets
Mar 17, 2003 09:57 AM
al
Nov 18, 2002 11:03 AM
MD Muhr
Nov 14, 2002 05:27 PM
turbospl311
Oct 14, 2002 08:23 AM
