Electrical Problem
Old Aug 23, 2009 | 11:31 PM
06DODGE59's Avatar
Electrical Problem
Ok here we go I have a 06 5.9 dodge 2500 4x4 auto everything.
Here is the prob. When i turn the key to the on poison to let the fuel pump charge the injectors the radio and BD out look come on. when i start the truck the BD stays on but the radio turns off and will not come back on. Some times both of them will go off and will not come back on. I have checked the fuses under the hood traced wires from under the dash to the fuse box. I do know that the radio, OBDII, cigarette lighter are all connected in some way the cigarette lighter still works like it should. The BD out look system plugs into the OBDII port.
Any help or suggestions
Old Aug 24, 2009 | 01:31 AM
BigIron70's Avatar
Cummins Guru
The Diagnostic CAN-C is used exclusively for the transmission of diagnostic information between the Totally Integrated Power Module/Central GateWay (TIPM or TIPMCGW) and a diagnostic scan tool connected to the DLC.
In other words take to dealer to reconfigure the TIPM.
Old Aug 24, 2009 | 03:44 PM
06DODGE59's Avatar
Ok well i was hoping it was something i could cure on my own
Thanks for the info BigIron70
bigredbrick
May 1, 2003 11:59 PM
feets
Mar 17, 2003 09:57 AM
al
Nov 18, 2002 11:03 AM
MD Muhr
Nov 14, 2002 05:27 PM
turbospl311
Oct 14, 2002 08:23 AM
