electrical problem
Old May 28, 2009 | 05:03 PM
bmxpxdude's Avatar
electrical problem
the problem started off slow. first the tempe guage would bounce. then my pyrometer would bounce to the turn signal being on. then the pyro would flicker with the AC being on. now the pyrometer wont ever work with the headlights are on and all the guages flicker at different times. any thoughts?
Old May 28, 2009 | 05:47 PM
Check the body ground on the core support by the battery.
Old May 29, 2009 | 01:04 AM
Philip's Avatar
There is also a body ground behind #6 valve cover. The dash grounds are located behind the cargo light switch.
Old May 29, 2009 | 02:04 PM
feveree40's Avatar
My pyro got real jumpy after i put an intercooler in. I had to mess around out by the core support and unknowingly broke off the terminal to the body ground in front of the battery. After I found the ground wire hanging free I reconnected it and all is good.
bigredbrick
May 1, 2003 11:59 PM
feets
Mar 17, 2003 09:57 AM
al
Nov 18, 2002 11:03 AM
MD Muhr
Nov 14, 2002 05:27 PM
turbospl311
Oct 14, 2002 08:23 AM
