electrical problem/question
Old Aug 5, 2006 | 11:08 PM
rjm022's Avatar
i noticed today when i open the driver side rear door-the odometer does not light up my mileage anymore. all other doors still work. this is not a big deal for me ( i am out of my 3yr/36.000 warranty) i imagine only three wires are involved-a power wire, a ground wire and a wire that goes to the odometer. like i said i can live with it, so i really don't want to rip the door panel apart and start tracing wires,etc. is this ok to leave?? or will it eventually cause a more major short/electrical problem-because i have a bad wire!!
Old Aug 6, 2006 | 10:11 AM
campnfish's Avatar
Does your dome light come on when you open the driver side rear door?
Old Aug 6, 2006 | 09:18 PM
handymantim's Avatar
Sounds like the switch/latch in the driver's side rear door isn't adjusted correctly or isn't making contact. When you hit the "lock" button does that door lock/unlock? The door lock motor and ajar switch are integrated. If the door doesn't lock/unlock then take the door panel off and see if a wire fell off.
Old Aug 6, 2006 | 09:22 PM
4x4dually's Avatar
I just have an old '02, but I'm a little confused at what a DOOR has to do with the ODOMETER?
Old Aug 7, 2006 | 05:08 AM
Hounddog's Avatar
Most vehicles the ODOMETER is blank turned OFF and when DOOR is open lights up and shows MILEAGE.
Old Aug 7, 2006 | 08:46 PM
rjm022's Avatar
dome light does not work either. no door locks switch-the ruck is an st model. all other doors work.
Old Aug 8, 2006 | 10:39 AM
campnfish's Avatar
Like Handymantim said, it is probably a disconnected or broke wire, or bad switch.
Robert Rausch
Feb 3, 2010 05:48 PM
feets
Mar 17, 2003 09:57 AM
al
Nov 18, 2002 11:03 AM
MD Muhr
Nov 14, 2002 05:27 PM
turbospl311
Oct 14, 2002 08:23 AM
