Electrical problem. Gurus???
Old Mar 30, 2005 | 05:28 PM
RTillery's Avatar
Repeat after me: always disconnect the batteries when messing around with the electrical!!!
I hooked up my fuel pressure gauge in a SRT-10 pillar mount. Works fine (well, about 7lbs at idle). The problem came when I went to hook up the lights to the gauge. I have a steering pod with EGT and PYRO so I tapped into the wire coming off my headlight switch to those two guages. When I hooked it up, problem! My intrument cluster lights, my dome lights, and my cd player have quit working. I disconnected the wiring and checked fuse 51 in the box (OK) but still no lights. Thought maybe I fried the headlight switch so I replaced it. Same situation. My fogs, headlights, and blinkers are working fine, but the indicators for the blinkers on the cluster are not working either. Help!!!
Old Mar 30, 2005 | 05:37 PM
MedicShawn's Avatar
Double check the wire still has power coming to it. Double check that it is being fed by positive and not ground.
Make sure you didn't turn the dimmer/domelight switch off.
Old Mar 30, 2005 | 06:17 PM
gcssr's Avatar
check fuse 18,22 and 41
the diagram shows fuse 18 powering the inst. cluster good luck
Old Mar 30, 2005 | 11:38 PM
RTillery's Avatar
GCSSR, you da man!
I had looked at fuses twice, but after reading your post, I got out my ohm meter and checked 18 again. Visually looked ok but ohm meter said bad. I got a strong light and finally saw the break. My CD player is still on the fritz but I had it out a few days ago. Maybe I pulled a wire on it. The radio works on AM and FM but does not register the CD at all. I cannot find a fuse specific to it. Will have to do some research but all lights are working properly. Thanks for saving me an embarrassing trip to the dealer.
Old Mar 31, 2005 | 07:25 AM
artesian's Avatar
Where can find a layout of fuses and what they control?
Old Mar 31, 2005 | 08:08 AM
RamWheelsBy4's Avatar
You can download the wiring diagrams from Dodge for just about anything electrical. This has power distribution sections on all fuses.
http://www.dodge.com/bodybuilder/
smokindog
Jul 21, 2006 12:29 PM
Murf
May 18, 2006 08:23 AM
spitfire9137
Dec 1, 2005 06:38 PM
HdPower
Nov 17, 2004 06:00 AM
scottrod
Dec 14, 2002 09:03 PM
