Electrical Nightmare !!!
Old 03-01-2009, 01:44 PM
andyboland's Avatar
Please help me out! Left low beam out, Right high beam out, Left Brake light out, No turn Signals. Now truck will not even try to start. FCM/BCM replaced, but made no difference. What the heck is going on?
Old 03-01-2009, 05:56 PM
gmctd's Avatar
Pull the taillites and park lites, check the bulbs for open, the sockets for oxidation\corrosion, clean as necessary, use ep chassis lube to weather-proof - also check the headlites and sockets for same - check the black ground wire that ties harness ground to the body for loose screw or connector
Old 03-01-2009, 07:07 PM
andyboland's Avatar
Where is the harness ground?
Old 03-01-2009, 08:35 PM
cbrahs's Avatar
TIPM
hope it isn't that. not cheap
Old 03-02-2009, 06:11 PM
gmctd's Avatar
You'll find a black harness\body ground wire near each light position, attached to the fenders\bed with a body-screw, maybe even a spade-lug on the late trucks
Prshby44
08-16-2005 11:10 AM
Prshby44
08-14-2005 10:35 AM
propinc
08-01-2003 11:11 AM
NWDave
03-27-2003 12:10 AM
Quick Reply: Electrical Nightmare !!!
