Electrical Issues
Old Feb 4, 2011 | 08:27 PM
alboy's Avatar
Electrical Issues
Jst got home from palm springs,1600 mile trip truck ran great till about 100 miles from home,had the clearance lights on the fiver on and all of a sudden had interior lights going on ,cargo light,now seems like a short when i put on the lights ,even with the fiver unhooked.ANY IDEAS APPRECIATED.
Old Feb 4, 2011 | 09:57 PM
CatDiesel_762's Avatar
Any trouble codes? I would guess you need a new Front Control Module. Do a search for Dome Lights. I do not remember if anybody ever solve the problem with out having to replace the FCM, ECM, or Instrument Cluster.
Shawn
Old Feb 4, 2011 | 10:06 PM
alboy's Avatar
THXS skim key code showed up ,cleared it no difference.When i turn on the headlight switch any interior lighting will dim and the overhead display goes right off.wondering if a short in the trailer might have affected the trucks electrical system.
Old Feb 4, 2011 | 10:18 PM
Could be. Our wiring is so messed up on these trucks that it is a wonder they even work half the time. I have an Inter-mitten brake light on with key off draw, which I believe is due to the Brake Controller.
Shawn
Old Feb 4, 2011 | 10:29 PM
madhat's Avatar
Administrator/Jarhead
A lot of times, when I see the skim key code, batteries are my first shot. Check both of them, make sure the connections are good, including the grounds going to the block.
After that, I'd start looking at the instrument cluster.
Old Feb 5, 2011 | 09:23 AM
alboy's Avatar
Replaced both batt in Nov/10, will check connecs thx
RD TRCTR
Nov 28, 2007 08:07 AM
nate_o23
Sep 21, 2007 09:59 PM
ontheedge
Feb 2, 2007 08:18 PM
caleb
Aug 26, 2006 09:02 PM
Micaiahfied
Dec 19, 2005 10:25 AM
