Egts soaring
Old 09-21-2008, 09:22 PM
0124vCTD's Avatar
Egts soaring
I was wondering if anyone had any suggestions about what to do about my EGT levels. Just normal acceleration in the interstate on ramp i hit 1200 to
1300 degrees under normal acceleration. The HX 40 i have on the truck seems to have a lot larger exhaust housing than is needed from what everyone i have talked to is telling me. I would like any input on what i could do to lower my egt's. I have looked into water meth injection but am not real impressed. But any input is appreciated. I have had it hit 1700-1800 degrees once.
Old 09-21-2008, 09:30 PM
1882's Avatar
Have ya considered ditching the airbox for a less restrictive setup? Won't be a cure all but will help. My EGT's are in better control with my tiny little HY35 and mods in my sig...
Old 09-22-2008, 12:03 AM
Tate's Avatar
Whats your boost at? Have you verified the pyro is correct? 1200 degrees just cruising seems awfully high for a turbo thats working right. The old first gens had housings that were up to 21cm and were ok, so anything on that HX40 should be keeping your engine cooler than 1200.
Old 09-22-2008, 05:01 AM
wurkenman's Avatar
With the box and your injectors, you will get higher egt's while accelerating. I can hit 1650 or so while on the pedal.
Old 09-22-2008, 09:57 AM
0124vCTD's Avatar
Running down the highway at 70 MPH with the cruise set it runs about 700-900 degrees. I dont have the airbox in there anymore just an open K&N.
Old 09-22-2008, 09:59 AM
0124vCTD's Avatar
What is the best way to go about verifying the pyro is correct. My Boost when accelerating heavily is 20-40 psi and just normal acceleration is about 5-20. How do i figure out what size housing in on the turbo.
Old 09-22-2008, 10:36 AM
Diesel Doc's Avatar
The size is stamped inside the ex inlet but it should also be on the outside of the housing on a holset. Look for a string of numbers on the ex casting usually the first 2 will be the size#.
Old 09-22-2008, 01:23 PM
sunsurf's Avatar
Up there, too
0124vCTD, I'm seeing same EGT's as you and my boost numbers match yours. I verified that my probe was located on the manifold and not downline (which might account for higher numbers). I'm at a loss as to why it runs so high. When I put my in-the-bed camper on I get nervous driving up grades as I usually settle into 14 or higher.
Old 09-22-2008, 01:56 PM
RowJ's Avatar
Level ground, 70 mph sustained ....... 700-750* would indicate, to me, your pyro is accurate!
Boost (no wind) should be in the 4-6 psi range, on an HX-40 at 70 mph, level ground.... if turbine housing is right size.
RJ
Old 09-22-2008, 04:40 PM
j-fox's Avatar
The HX40 probably has a 16 exhaust housing. find a wastegated 14, it should really help.
NOTSTK
08-09-2003 09:10 AM
doug
103
07-02-2003 02:27 PM
thecatsfan
16
06-20-2003 10:36 AM
cowpie
01-29-2003 09:08 PM
1ST GEN.
10-19-2002 08:45 AM
Quick Reply: Egts soaring
