egts get hot fast
Old 01-03-2008, 08:03 PM
450r's Avatar
egts get hot fast
i have a 05 that is pretty much stock i have a 4 inch hole in the bottom of my intake and amsoil nanofiber filter and i have a muffler delete i just installed the quad recon gauge set
so my question or problem is that in that form if i punch the throttle in my truck the egts climb to like 1360 or higher in no time (like 100 yard) i have my gauge installed where quad recommends on the top of the manifold in the middle .
so why does this go so fast any ideas could it be the treatment in the fuel for winter making this much difference ???
Old 01-03-2008, 08:07 PM
BBarnett's Avatar
Thats normal.
I could hit 1450 when my truck was stock.
Brian
Old 01-03-2008, 08:16 PM
450r's Avatar
just seems like if i wanted to try to outrun someone i wouldnt be able to hold it long then id have to let them get me
Old 01-03-2008, 08:20 PM
BBarnett's Avatar
As long as it is stock with no power adders I wouldnt sweat it.... The
S T E A L E R I mean dealer should fix it....
My 05 and my 07 both would run around 14-1500 when stock...
My 6.7 would do the same too///...
Old 01-03-2008, 08:24 PM
stock600's Avatar
Dont see that you have a tuner or box. Take your pick on one of these and youll see power, milage, drop in temp., and tons more fun to drive. Lots of guys would rec. the smarty, that would be a great chioce or if you dont have 650. to drop you could get like a edge ez or simular for around half that and have pleanty of power. With my tuner the egts are better than stock unless im hard in it on the 215hp setting, and milage is way better than stock even on that setting. TURN IT UP!!!
Old 01-03-2008, 08:29 PM
450r's Avatar
ok this was before i installed my quadzilla xzillaraider tonight man does it make alot of fun i was mainly concerned that it did it stock now if i put it on 100 hp setting it does it at mid throttle on the 60 hp setting its about the same and i havent messed with the 30 hp setting yet but anyone think it could be the winter fuel treatment making it burn hotter too
Old 01-03-2008, 09:40 PM
rustyshakelford's Avatar
does the quad do any boost fooling?
brett
Old 01-03-2008, 10:28 PM
quadman20's Avatar
I'd have too think he has an X1 mod not an X2 with a 30-60-100 hp so I'd think BF working then. Just a guess.
Old 01-03-2008, 11:49 PM
UnrealTrendz_OR's Avatar
this might sound funny but my egts in an hour of hard driving around town and hiting long back roads my EGTS dont even touch 900 and this is on setting 5 on my EDGE. and i do have a heavy foot. (IS IT BROKE!!!!)
Old 01-04-2008, 01:10 AM
1stGen545's Avatar
my brothers 07 5.9 6spd with Edge Juice w/Attitude 5X5 will hit 1500* pre turbo in a few seconds empty. Is your probe pre turbo?
Old 01-04-2008, 01:14 AM
trik396's Avatar
Sounds like something else is broke... like your egt guage. You should be way above 900 especially with a stock turbo... Be careful.
Old 01-04-2008, 01:16 AM
dodgecowboy04.5's Avatar
My Egts are the same way. With my juice set at 5 mine have never seen over 750, and that is going up hill, but I have my pryo post turbo so what would the real temps be.
Old 01-04-2008, 01:34 AM
trik396's Avatar
More...
Seriously you should just go pre turbo. Educated guess around 300-400 more.
And if you're reading it from an Edge digital guage, they have been known to be off.
Old 01-04-2008, 01:43 AM
RRC
RRC's Avatar
Heya 450R, check out THIS thread I started . . .
Old 01-04-2008, 08:24 AM
jrussell's Avatar
Originally Posted by 450r
...anyone think it could be the winter fuel treatment making it burn hotter too
No, but it could be the cold outside air temps inflating your max EGT's. For some reason colder air temps will lower cruising EGT's but actually increase max EGT's. Mine hit 1550* (with the twins!) yesterday in 48* temps and it usually maxes out at around 1400* in 80-90* temps.
I agree. No way an '05 should max out at 900*...stock or with a chip. I would double check that pyro for sure.
Quick Reply: egts get hot fast
