EGTs and Boost
Old 07-22-2010, 09:36 PM
97DodgeRam's Avatar
EGTs and Boost
I have noticed when I tow with my truck and the EGTs get warm (~1200F), my boost is only around 25-30 lbs, even when I'm above 2200 RPM. If I give it more fuel and reach 35 pounds of boost, my EGTs are too warm (1400F). This doesn't bother me too much and I try to keep my EGTs 1200 or less. My adjustable boost elbow is screwed all the way in. I was just wondering if anyone else has noticed the same thing as I have.
Old 07-22-2010, 11:35 PM
Brendan's Avatar
you have got a ton of fuel for a stock turbo, that alone will make it hot. Have you checked for any boost leaks? with all that fuel you should be able to see 40+ pounds of boost.
Old 07-26-2010, 06:10 PM
97DodgeRam's Avatar
I can see 45+ lbs of boost if I really get on it. I would like to get another turbo(s), but being in college puts a damper on that fund.
Old 07-26-2010, 10:42 PM
Brendan's Avatar
If it's just for play pick up a second hand hx40 or something cheap off of craigs list, probably get there for a couple hundred bucks.
Old 07-28-2010, 10:05 PM
BLACKDRAGON's Avatar
Tons of fuel for the stocker!! Is this a pullin or racin truck? Maybe look into a hybrid for cheap. Imo opinion I would get rid of the lc dvs and the plate is only hinderin you rack travel mod.
hemirunner426
02-25-2010 12:39 PM
WY FARMER
10-15-2009 10:34 PM
archer39
09-14-2009 05:25 PM
jrs_dodge_diesel
01-26-2007 08:33 AM
m1a convert
04-24-2004 11:27 AM
Quick Reply: EGTs and Boost
