EGT's all over, think I need a new probe.
My EGT's are all over the place. Climbing a hill they should be about 800 all the way up the hill. I am seeing anywhere from 130 to 800. The other day I left from a cold start and my edge j/a alarm went off for 1500. I only had gone 200 feet. Do I need a new probe? and where is a good place to get one?
Eric
Eric
I get most my parts from Genosgarage or Diesel Manor
http://www.genosgarage.com/departments.asp?dept=2
http://dieselmanor.com/
First check all of your wiring connections. Is the needle sparatic or just slowly sweeping? I've had both, the sparratic movement was caused by a thermocouple wire cutting through the insulation and contacting the steel body. The sweeping was caused by something loose in the back of the gauge. I found that when I push on the gauge a certain way I can make the gauge go from its "false reading" to a realistic reading. I think an internal terminal or solder is a little loose on mine...
wiredmojo
27
08-31-2005 11:44 AM
Dave65
10-08-2004 10:37 PM
