EGT way to hot
Old 05-20-2007, 01:22 PM
killed300ex's Avatar
EGT way to hot
Wondering if it was normal for EGT to change very quickly? My 94 CTD with a #6 plate and 3k GSK, stock pipe size (straight piped) with a k&N drop in filter will go from 600 just cruising around and if I floor it for more than 2-3 seconds the temp will climb about as fast as the guage can accomidate I end up backing off at 1350 but I am sure it would go way past 1400. Is this normal? If not what can I do to try to calm down the exessive temps without going out and spending huge money. If I baby the truck it stays right around were it should 600-800 just normal driving.
Help
Evan
Old 05-20-2007, 02:12 PM
kawi600's Avatar
Check for boost leaks and slipped injection timing. Otherwise thats pretty normal. I can get mine up there in about that amount of time.
Keep an eye on boost too, you dont want to go over 38psi
Old 05-20-2007, 02:18 PM
Muddin_dude06's Avatar
He is right, those would be the biggest two culprits. When I advanced my timing it was only at 8* So advancing it to 18* dropped my EGT's about 400* or so at WOT.
Old 05-20-2007, 03:20 PM
DTR question asker
dieselfuelonly's Avatar
Also you have a #6 plate, that thing is pretty nasty .
Old 05-20-2007, 03:50 PM
Box5's Avatar
still, ur 94 shouldn't heat up that quick with just those mods on a 160 pump.
Old 05-20-2007, 03:53 PM
Box5's Avatar
I mean If I hold WOT for 5 seconds the boost flys up to about 35 and the temps go with it, but they don't reach above 1100 IIRC
Old 05-20-2007, 04:20 PM
I was wanting to get it retimed because I think it might have slipped since the fuel economy is kinda bad. I just have to find someone local to do it. The closest preformance shop is about 2 hours away. Hopefully that will take care of alot of my issues.
Evan
Old 05-20-2007, 05:35 PM
joshua smith's Avatar
With my 97 ctd in my sig, if I hold wot for 4-5 seconds, wether from a dead stop or 20 mph, I can hit 1700* FAST!!!!!!!! I have a stock pump and turbo with a k&n drop in filter. I can get 38 lbs of boost, and I have gotten to 1775* before. I have the wastegate elbow on from tst. I have not touched the timing.
1997 CTD 2500 ex-cab long box 4X4 235,000 miles, gear vendors 8 speed overdrive, stage 5 TST fuel plate, 4" exhaust, 370 injectors, full DTT trans, turbo silencer MIA, X-monitor guages, 4:10 gears w/limited slip, new style tow mirrors, stock turbo and pump
2004.5 CTD HO 2500 4 door long box, stock for now
Old 05-20-2007, 06:02 PM
JKM
JKM's Avatar
With a 10 plate and DV's in my 95 i could peg my 1600 deg pryo REALLY quickly , now with a boost elbow , air intake , exhaust , and timing , it levels off around 1100 deg under full power.
Old 05-20-2007, 10:44 PM
kas83's Avatar
You're also running a bigger pump, so you're already ahead of the game with fuel over a 94.
Old 05-21-2007, 07:14 AM
jlipskoc's Avatar
Evan, we have the same pump, sounds like you need to up the timing to 15-16.
I ran the #6 plate on the stock inj, turbo, dv for years, and on hills I could get it to 900 cruising. 600-700 flat.
On the dynojet I made 239 hp, 525 ft lbs. I didn't have the timing done yet, and had a bad lift pump, overflow valve, i would problably made 250 if i went back after fixing stuff.
1200 is easy to get to on the stock turbo with #6, even after I did the timing it helped a little, though it'll take a good WOT run and top gear, going pretty fast to boot. EGT's were better after the retime, little slower to move up.
I can hit 28lbs then it would back down to 25lbs of boost.
Old 05-21-2007, 07:30 AM
BigErksG2's Avatar
i didnt see if you put in a boost elbow.... if youre adding more fuel, you need more air. 30-35psi is the ticket for me. i can hold it almost wot up a whole mountain and never get above 1250. it usually goes back down once i build full boost. good luck
whosdunit
02-16-2019 04:07 PM
tx02
27
09-08-2009 04:38 PM
Strjock81
16
12-12-2007 09:53 AM
edwinsmith
04-14-2006 03:53 PM
duallydave
08-07-2005 09:38 PM
Quick Reply: EGT way to hot
