Egt
Old 09-05-2011, 10:52 PM
jkoons's Avatar
Egt
What if anything can I do to lower my egt towing, in o/d at 65 mph and 1800rpm around 1000*,out of o/d 60 mph 2200rpm around 700*
02 Ram3500,CTD,3:55 gear,10,000# 5th wheel
Thanks Jerry
Old 09-05-2011, 11:08 PM
totalloser's Avatar
Check for boost or preturbo exhaust leaks, put on 4" exhaust. Especially look at the exhaust manifold for cracks/warping. Preturbo leaks prevent the turbo from spooling adequately which leads to high egt's
If your chip does "boost fooling" get a "boost elbow" to turn up your turbo or a J-hook if you have a hy35 (can't remember if dullies ever came with them). Probably won't matter most the time since you probably wouldn't go over 20psi except when accelerating hard, but if you're seeing high egt's at full boost, this will help a LOT with that.
Since you're worried about 1000* I'm assuming your probe is post turbo. Preturbo you don't have to even be concerned until you're consistently over 1150*
jmccart
03-18-2007 10:03 PM
jmccart
11-20-2006 06:45 PM
Hummin Cummins
03-20-2003 07:20 PM
Quick Reply: Egt
