egt question
Old 04-19-2004, 10:13 PM
teachfox's Avatar
egt question
with my setup (see signature) from wot 0-70mph on flat ground on a 60 degree day i'm only seeing 600 degrees post turbo temperature. at cruise i'm around 400 degrees at 55mph. does this sound right? i pulled egt probe and took a butane turbo torch to the probe and the gauge rose to 1200 degrees. just wondered if i should be seeing more temperature than that? thanks in advance.
Old 04-19-2004, 10:25 PM
Steve Roseman's Avatar
Since you're running your probe post turbo, you need to figure your boost numbers in also. I think I read that you can add about 100 degrees for every 10 psi of boost. To me your readings sound low, but my knowledge is limited.
Old 04-19-2004, 10:39 PM
teachfox's Avatar
i'm running about 38psi of boost. in that case i guess it would be about 1000 degrees?
Old 04-19-2004, 10:42 PM
billg's Avatar
That’s about right if you are post turbo. Add 300* (that is what you loose through the turbo) to get the pre turbo temps. I would move the sensor to pre turbo.
With the EDMs I get about 250* at idle, 600* at 65 mph, and 1200* spike at WOT and then 900* when the boost catches up (and that doesn't take long).
jmccart
03-18-2007 10:03 PM
jmccart
11-20-2006 06:45 PM
bsummit
06-21-2003 04:28 PM
Farmout
05-15-2003 10:06 AM
Quick Reply: egt question
