View Full Version : Egt Probe for 3rd Gen.
Scotty
12-04-2002, 09:58 PM
Heres a couple pix of the EGT probe install...
Scotty
12-04-2002, 09:59 PM
2nd pic...
rebby
12-04-2002, 11:00 PM
very nice... what gauge setup did you go with? where did you mount it? etc, etc, etc... <br><br>i can't wait to get my truck ;)
pwabbott
12-05-2002, 12:13 AM
Looks good, Scotty. I want to install an EGT probe and gauge when they arrive. We all need more details, point us in the right direction. ??? ???
Scotty
12-05-2002, 12:21 AM
Isspro gauge...Pods are in prototype mold form now and hope to have some formed in the next few weeks.<br>We just have the gauges in cups stuck to the top of the dash with velcro til our pods are done.<br>Scotty Air III is getting close... ;)<br><br>
misterKTM
12-05-2002, 03:06 PM
Looks good. I'll be puttin gauges on as soon as I get my truck (going to order with 2-3 weeks). <br><br>Question for you....did you remove the turbo to do the drilling and tapping for the probe ?<br>
Scotty
12-06-2002, 10:36 AM
No we left the turbo on...use grease on the bit and clean it often...then use a magnet in the hole to collect the shavings...on start up the small amount of what might be left gets pushed out the exhaust. I have done it this way on many many trucks. No problemo.
misterKTM
12-06-2002, 04:01 PM
That is the method I used on my '97 - and it worked great. But, I was concerned about the '03 with the placement of the turbo. It is directly underneath - it seems that any shavings that fall on the inside are going to fall out of reach - where on the '97 they just fell down and landed right under the hole where I picked them out with a magnet.....But that is encouraging that you didn't have any problems - I hate to pull the turbo off.<br><br>Thanks<br>rob<br>
Push Rod
12-07-2002, 12:25 AM
<br>No we left the turbo on...use grease on the bit and clean it often...<br><br> [laugh] Boy we have great communicaton within Wildcat. Scotty and I discussed the pyro install, and we decided to do it as he had mentioned. <br><br>Then I got to looking a little closer at everything, and decided to be anal, so I dropped the turbo, and stuffed a rag in between the manifold and the turbo. I'm glad I did. Even heavily greased, a magnet, and a shop vac, when I pulled the rag away it had alot of shavings on it. Now I realize that the shavings would need to wedge between the impellor blades and the housing to cause any damage (not likely), I decided that with my luck, something would likely happen [laugh]<br><br>So I'd definitely recommend dropping the turbo on the 03's.<br><br>Rod
Scotty
12-07-2002, 12:46 AM
:(<br><br>Well at least I got the pix correct. [laugh]<br><br>Sorry for the confusion folks...I was going by what our last conversation was before he tackled it. [eyecrazy]<br><br>EH
pwabbott
12-07-2002, 01:45 AM
Push Rod & Scotty, How about dropping the turbo and inserting a sheet of galvanized in between turbo and manifold to catch the metal filings? Afterwards slide out the metal with filings on the surface.
Push Rod
12-07-2002, 08:28 AM
That would probably work, but you'd have to be careful not to tilt the galvanized when pulling it out, otherwise the shavings could slide off. With a shop rag, the shavings tend to stick to it.<br><br>Rod
