egr help now
egr help now
i just unplugged my egr and it started loaping real bad, i tried to drive it and it poured smoke and shuttered bad. All i unplugged was the one plug up top on the valve itself, any help would be awsome
thanks,
Dayton
thanks,
Dayton
butterfly closed?
On some, depending on flash version. the electronic throttle butterfly plate will default in the closed position, choking off the intake air. You'll either have to remove the plate or update the ecm.
Mine would do the surge, stumble thing only at startup once in a while. I ended up removing the butterfly.
jeff
jeff
Did you un-plugged the correct one? Another user on one of these forums un-plugged the incorrect one and his acted similar to yours. I woukd do a search on this forumlooking for un-plugging the EGE and deletes. I believe there was instructions and pictures show the step by steps needed to remove the ERG vavle along with un-plugging the EGR. I also believe the writer stated you needed to have the latest flash for your model year.
Hope this helps. $0.02
camshaft01
15
06-09-2015 03:43 PM
WaFLHTRider
06-13-2011 05:29 PM
Black98LS1
19
12-13-2009 09:32 AM
MOJO1
08-04-2009 06:28 PM
