View Full Version : Edge system
usmarine110786
02-04-2009, 09:39 AM
i got my edge juice with attitude in but it still dont work the only thing it does is read the egts and trans temp. it wont change levels, it reads 0 fuel press, and wont fuel past 2200 rpms.
scottsjeeprolet
02-05-2009, 06:17 AM
Chris post this over in the 2nd gen performance section.
You can bring it over and we can have a look at it.
Have you called Edge about it?
dzlfarmboy
02-05-2009, 12:35 PM
And you have everthing hooked up right? Map sensor, Pump wire tapped,data conection link hooked up and the unit hooked up with a key on power.
usmarine110786
02-05-2009, 01:31 PM
yea i hooked everything up and called edge they said i would have to take it to an instlitation specialist. i will bring it over whenever ur free to look at it just let me know thanks.
06 DIESEL
02-07-2009, 02:58 PM
He is over here now and everything is hooked up properly as far as I can tell. I did pull four codes though
P-0500 - Vehicle speed sensor malfunction
P-1693 - DTC Detected in companion mode
P-1694 - Fault in Companion Mode
P-1687 - No Cluster bus message
Since I do not have access to a code reader/clearer here for a second gen I am asking that someone out there that has the ability to do with to a second gen please send Chris a PM and try to hook up with him to get these codes cleared.
06 DIESEL
02-07-2009, 05:46 PM
I think we might have found the problem. His positive battery terminals were loose so we tightened them. He also had a deal lift pump so we replaced that. The truck seems to be running better now, I will let Chris chime in and let us know how the drive home was.
06MegaCTD
02-07-2009, 05:50 PM
**** ya'll had a spare lift pump in the cave lol.
biggerkin
02-07-2009, 07:35 PM
whats in the cave[laugh][laugh][laugh][laugh]
06 DIESEL
02-07-2009, 07:44 PM
Yes there was one in the cave but we were not sure if it worked or not. He bought one at Salvo that has a lifetime warranty, so he is good now.
md-rebel
02-07-2009, 11:15 PM
No one really knows ......... (add creepy laugh)
usmarine110786
02-08-2009, 12:03 PM
well i still have codes thrown and i need to get the ecp reset on the truck if anyone knows where i can get the computer reset.
scottsjeeprolet
02-08-2009, 02:40 PM
We have a code reader at work. I'll bring it home and we can clear the codes with it.
lukedaemon
02-08-2009, 07:17 PM
I have a scanner/reader too. Not the top of the line type, but does the job.
rollincoal02
02-08-2009, 09:10 PM
find someone with a smarty local...it will clear the codes
bootsdodgejn
02-09-2009, 08:29 AM
I know i always have. Vehicle speed sensor malfunction code. Going to check into at school today in advanced diag class.
Sea:\>Drive
02-09-2009, 12:12 PM
You can get the P0500 code from slipping your tires. It is saying that some tires are reading different speeds than other tires. I usually have that one as well - guilty[nonono]
usmarine110786
02-09-2009, 05:54 PM
i was told that i need to get the trucks computer reset compleatle to fix all of them bc even the radio isnt working the audio input and output code was thrown and 3 for the trubo. i got them cleared at the auto store and it did nothing.
rollincoal02
02-09-2009, 05:59 PM
wish i still had my smarty...i could fix it then
dangit
usmarine110786
02-09-2009, 06:40 PM
i just dont want to have to take it to the dealership to get it reset
rollincoal02
02-09-2009, 06:51 PM
find someone who has a smarty locally, they can reset your ecm with a stock tune.
contact brett at TNT, he is on the eastern shore but i think he or one of his buddy's have a smarty and could take care of it pretty quick if you went to see them.
