Edge releases the 600 Juice with Attitude TODAY!
Old 12-23-2004, 04:33 PM
Big Bob's Avatar
I just talked with Justin at Edge Products. He told me that they released the 600 Edge Juice with Attitude Today! Yahoo! Bad note is, Justin said the HP rating is 40 to 100! However, from what Aaron had told me before, they will be offering an "Off-Road" version which you will have to sign a wavier to get.
Now the waiting game again for the 555 Juice with Attitude! Hopefully in a month! I hope the HP is where my Beta model was! I dyno and the Juice with Attitude for the 555 gave me 133 HP increase!
Old 12-23-2004, 05:45 PM
WhiteSport600's Avatar
You mean that you guys have been doing all this waiting just for another 100hp box???
Old 12-23-2004, 06:28 PM
AK RAM's Avatar
That might not be that bad. The 130hp (100hp dyno verified) VA duration box that I play with will get up and go pretty good, just too darn hot without timing. For those of us with abnormal trucks that can't/won't run the TST because of the constant misses and sputters we get, this may just be the trick. Dollar wise, I have a feeling it is going to be a little expensive for the power gain you get. You figure an adjustable timing/duration box for the towing crowd that wants to stay away from pressure......this will be right up their alley. Throw in a set of EDMs for a wicked daily driver, then stack with pressure for race day. The ticket will be if/how much timing they were able to do.
Old 12-23-2004, 07:42 PM
Big Bob's Avatar
I heard from Aaron today after my initial post. He said that and I quote him:
"Please remember we will have a free HOT JUICE upgrade. I think you will find the Juice to run real smooth and it uses less fuel to create the same amount of power as other modules out there. I will go into more detail later. Please don't give up on us." and "by the way the HOT will be much better than your first BETA box. TRUST ME!"
Now he really has me excited!
Old 12-23-2004, 07:45 PM
AK RAM's Avatar
OK. You got my attention.
Old 12-23-2004, 08:37 PM
B.Law's Avatar
So the Juice does timing and duration only? No pressure at all?
Old 12-23-2004, 08:56 PM
nickleinonen's Avatar
i was kinda hoping that it would be an all in 1 box... pressure, timing, duration... but a juice box with the A2 controller would be sweet... maybe for christmas next year [i've got a short throw shifter coming for this year ]
Old 12-23-2004, 10:12 PM
Big Bob's Avatar
You are correct, timing and duration only! No Pressure.
Old 12-23-2004, 10:25 PM
deere nut's Avatar
Can you comment on the EGT readings with your Beta module? THis may be the box a lot of tow people are looking for.
Old 12-23-2004, 10:48 PM
Big Bob's Avatar
deere nut,
You can set the Juice w/Attitude to defuel and whatever temperature you want. When I tow with it, I would run either 2x5 or 3x5 (depending on the terrain) and set it to defuel at 1200 degrees. It is great for towing!
The highest EGT's I have experienced is about 1460 on 5x5 with just the Juice. Right now I don't have the Beta, I sent it back to be upgraded the end of July and then Edge put the 555 Juice aside and went full steam into the 600 Juice. I hope Edge will have the 555 Juice completed in a month or so.
Now this next infor I'm going to share with you, I am pulling out of my not so good memory. If I remember right, even when you set the Attitude to the highest defueling setting which is I think 1500, you can over-ride this setting by pushing a button twice (I can't remember which button without looking at it), anyway this would over-ride the defueling for a choice of 1 minute or, I think it was 5 minutes (not sure about the 5 minutes). But anyway, if you were going to race someone, you can over-ride the defueling.
The Attitude also has a memory for highest numbers, example: Highest EGT's, Highest Boost, etc. It keep them in memory and you can recall them for reference or delete them if you want.
Old 12-24-2004, 09:45 AM
Mopar_Mudder's Avatar
I have been very patiently waiting and supporting Edge on this, but I got to say that they fact that they are skipping on the 555 and makings us wait is a bunch of BS. Very disapointing in my mind. But I guess that is what you get when you own a 2 year truck...............
Old 12-24-2004, 10:00 AM
Got Juice?'s Avatar
Double tap dance on the lower button (enter IIRC) and you do into 'bypass safety ' mode.
Old 12-24-2004, 04:10 PM
Big Bob's Avatar
Thanks Juice! I knew if you saw this you would help out!
white250005
10-29-2007 10:51 AM
Texaschevelle
08-25-2007 02:16 PM
04Red3500
12-14-2006 12:05 PM
Tyler_02
01-24-2006 09:09 AM
RamWheelsBy4
23
02-17-2005 02:15 AM
Quick Reply: Edge releases the 600 Juice with Attitude TODAY!
