Edge Programmer ?
Old May 20, 2012 | 12:49 PM
vrtical's Avatar
Edge Programmer ?
Anyone here running an Edge Juice Programmer? If so What setting do you use for normal driving, and best fuel milage? I've been on 1 but fuel milage hasn't been that great.
Old May 20, 2012 | 03:00 PM
Reelay's Avatar
I have an Edge Juice W/A I run on 3 when not towing and 2 when towing. The number 3 setting seems to get the best MPG for me. I generally use those two settings never have used 4 and I don't have the "hot unlock" option don't need it for what I do. I am sure others will chime in on this post.
Old May 20, 2012 | 07:40 PM
vrtical's Avatar
Thanks, I tried 3 for a little today. Seemed like I had a little more low end torque. Might try running a full tank of fuel on this setting.
Old May 21, 2012 | 12:07 AM
alboy's Avatar
I,ve had the E/ATT on since new and quite happy with it,tow on 2, 3 running empty.Don,t think there are any fuel savings that i,ve seen,but similar mileage weather its on or off towing.You can play around with the fuel settings for low or high end fueling, makes quite a diff in performance.
Old May 21, 2012 | 10:39 AM
Falcon1's Avatar
I run the juice W/A on 3 milage gets a little better on 1 not much differance maybe a mile or two.
Old May 21, 2012 | 09:20 PM
vrtical's Avatar
Sounds like 3 is the setting to go with. Do you all notice any power gains?
Old May 21, 2012 | 09:31 PM
Reelay's Avatar
I have noticed power gains compared to settings 1 and 2 at 1800 rpms and up. When I was towing my fiver the edge went out back to stock then I really felt the power difference. Sent the edge back in to have it updated and the monitor replaced. No problems since...
Old May 22, 2012 | 08:13 AM
Falcon1's Avatar
Yes you can feel the difference. How much it makes? I'm still running stock injectors and turbo but you can still feel it pull and smoke a little so it's doing something.
Old May 22, 2012 | 07:29 PM
vrtical's Avatar
Thanks for the responses, I'll run it on 3 for awhile. Wonder if the 4 or 5 setting does anything worth while? I know the book says not to use these settings w/o engine mods , but sometimes they are over cautious.
morkable
Feb 15, 2007 10:23 AM
SconsinSmoker
Jan 29, 2007 04:27 PM
onebadmudder
Nov 6, 2006 07:25 PM
jlells01
Oct 18, 2004 06:50 PM
thecatsfan
Feb 11, 2004 01:58 PM
