Edge Juice w/A - should I unlock hot ?
Old 02-08-2010, 11:39 PM
skidlyman's Avatar
What do you think, is it worth it to unlock my hot code on my Edge ? Just exactly what will it do for me. I use my truck as a daily driver and don't hotrod much. I pull a 5th W toyhauler maxing at under 9k a few times a year.
Old 02-09-2010, 12:11 AM
DodgenIt's Avatar
If you dont hotrod much, Id say leave it locked and get those injectors you want.
The extra fueling betewwn 2700 and 3200 rpm isnt noticeable IMO and if you just DD and tow once in a while, you fo sure wont notice it.
All it will do is give you higher EGT's and more smoke.
JMO.
Old 02-09-2010, 06:44 AM
milesfelix's Avatar
You'd probably not notice the gain. I'd still get it anyways just to have it lol. It's always fun to goose it once in a blue moon.
Old 02-09-2010, 09:29 AM
Beast2B's Avatar
clutch first, turbo and sticks next. I couldn't save my stock clutch with an EZ! ...and I drive like a grandpa (which I am, so I guess that's OK)
Old 02-15-2010, 02:03 PM
diggerfan99's Avatar
Judging by the threads I have read, (getting a J/A soon), I should not even bother tapping the pump wth my stock automatic tranny?
Old 02-15-2010, 02:09 PM
kyncl's Avatar
Tap the pump. The trans will be wasted in a small amount of time either way. Get and good transmission and let the fun begin. I didn't tap the pump right away and my trans didnt last very long. Maybe a few months.
Old 02-15-2010, 02:57 PM
Bummer, was hoping trans would last a little while, so budget wise what transmission is best to replace it with? Or, can I have the current one rebuilt and beefed up?
Old 02-15-2010, 03:04 PM
kyncl's Avatar
I should back up... you could get by for a while. But, I had to much fun and kept puting the juice on #5. If you can keep your foot out of it, you will be okay for a while. But the power is addicting! I chose the Georends transmission out of Iowa. They have a very good trans.
Old 02-15-2010, 03:14 PM
Cool, I'll check it out, I don't do alot of heavy towing but I drive 70 miles to work and back everyday and want some extra passing power on the highway, figured a small power adder would work but by the time I bought gauges I could by the J/A.
Old 02-15-2010, 05:37 PM
Sorry about side tracking the thread guys, but I have one more question. I have a Fass 95 Series setup, is that Ok for the J/A. I don't plan on running it on level 5 much.
Old 02-16-2010, 06:35 AM
pgdsm's Avatar
Fass 95 will be fine
chadsdodge
06-10-2008 07:34 PM
STROKETHIS1
13
05-14-2008 12:43 AM
03RAMBUNCTIOUS
13
02-16-2008 10:33 AM
Texaschevelle
09-12-2007 10:44 AM
cbrahs
41
08-25-2007 12:18 AM
Quick Reply: Edge Juice w/A - should I unlock hot ?
