Edge Juice Boost #'s
Old 09-01-2007, 04:18 PM
GrizzlyAdams's Avatar
I'm just try to see what kind of numbers you guys are seeing on your stock turbos. The highest I've seen was pulling a 5K trailer up a long grade...34lbs
Whats your highest??
Old 09-01-2007, 04:49 PM
Administrator/Jarhead
madhat's Avatar
40-41 here. See photo gallery for proof...
Old 09-01-2007, 05:20 PM
Proud Rebel's Avatar
36 to 37 here.
Old 09-01-2007, 05:33 PM
I think once I get rid of the stock exhaust my numbers will be higher..
Old 09-01-2007, 06:06 PM
madhat's monkey boy...
matego's Avatar
I have my stocker set at 40 psi but have seen 48-50 spikes before I put on a external boost controller. I tow nothing, which I think is why it is still together.
Old 09-01-2007, 06:41 PM
CamperAndy's Avatar
I can pull a steady 40 psi on grades when towing my 7K trailer. Have the Attitude set to alarm at 40.
Old 09-01-2007, 07:38 PM
BgBlkTrk's Avatar
Have seen peaks of 36-37 usually around 33-34
Old 09-01-2007, 07:45 PM
txfiremedic's Avatar
My A2 alarm is set for 40psi and it will hit it easily under hard acceleration with the Juice on level 3.
Old 09-01-2007, 08:01 PM
powermad's Avatar
hold on so you guys are getting 45 psi out of a stock turbo?! what kind of egts are you hitting? if egts are managable i wish i didnt spend 1400 on a aftermarket turbo
Old 09-01-2007, 08:07 PM
Personally I've never hit 45 that I know of. And as far as EGT's go, as soon as the alarm goes off on the A2 I let off the accelerator. My truck doesn't go to the track and Im not out to race, so I would never spend that kinda cash to upgrade the turbo. The Edge does ALL I need/want!!
PS. Powermad, fill out your signature so we can see what you're driving!!
Old 09-01-2007, 11:12 PM
3500_CTD's Avatar
i have hit over 45 on my truck with the edge juice on level 5 (HOT)
Old 09-01-2007, 11:22 PM
matego's Avatar
Powermad, It is always a good idea to upgrade the turbo when you can. The only reason I run the stocker so hard is because the class I run in requires a stock turbo. I have always wanted to see what the temp is going into my intake at 40 psi, but I am scared of what I might see
Old 09-01-2007, 11:23 PM
You mean level 6??
Old 09-02-2007, 12:39 AM
Megacab07's Avatar
The highest I have seen is 38 psi on level 3
Old 09-02-2007, 10:52 AM
3500_CTD's Avatar
Originally Posted by GrizzlyAdams
You mean level 6??
no on the 04.5 - 05 models you dont have a level six cuz you have to send it in to get upgraded and the just reprogram level 5 you cant add the level 6 on mine
Quick Reply: Edge Juice Boost #'s
