Edge Juice/Att and Smarty???
I have an Edge Juice/Att stacked with an Edge EZ box and they work very well with no problems. My question is about the Smarty, I have read it does not work with the Edge stuff but If I take off the EZ and set the Juice to stock so I am just using the Smarty's power will the guages on the Attitude work? Anyone have the Edge stuff AND the smarty on thier trucks at different times and have any comments on the 2 products first hand?
I hear if you run the smarty without the timing, it stacks fairly well on the Common Rails. Not as well as the TST/smarty stack but pretty well none the less.
I have the Diablo Predator on with the Edge/Attitude and guages work fine with edge on 0. Just remember to plug the diagnostic port wire back in after the download. Ive also recently discovered that if I run the Edge on 1 with the Predator it runs much better. Edge doesn't seem to boost fool on 0 but definately seems to on 1? I don't think the Smarty does boost fooling so I would imagine your results would be the same as what I did. Could be wrong though - it's happened before. I wouldn't advise running Smarty and Juice together on higher settings though - too much timing. Good luck.
The Juice and Smarty(don't know about the programming coming out) do not work together to add power. As soon as you download the Smarty, the Juice will not add power on any setting - at least in my experience. The Attitude monitor does still function as far as the gauge aspect - not sure about the safety features. As far as comparing the two, before I had injectors, the Smarty didn't make any more power on my truck than the Hot Juice, so I sent the Smarty back and kept the Hot Juice since it was adjustable on the fly.
The Diablo Predator does work with the Juice fairly well - better on the 305/555 engines than the 325/600 engines.
I was suppose to have already done some dyno testing with the Smarty beta and Hot Juice but that hasn't worked out yet. Hopefully I'll have some info in a couple weeks to post.
dont do the smarty
Like Omaharam said.... doesnt add anymore power save your money for a turbo.... thats where your going to get the bang for the buck..... you have enough fuel.... That set up with twins will be frantastic
jmmcdona
13
02-01-2010 03:33 PM
TORQUEWILD4X4
28
02-26-2009 07:02 PM
Jordan5687
10-01-2007 08:26 PM
JIT
10-19-2006 09:55 PM
ocsurf16
10-04-2006 10:19 PM
