edge ez.....or, ts mp-8(ramifier)
looking for a crisper bottom end than the ez provides w/out cranking the rail pressure to high. don't like the idea of downloaders so is a ramifier a good option? would like some more sooty smoke too! my current smoke pics are in gallery
NAPA, my Quad box gives much better bottom end than either my old EZ or my new Van Aaken box. I would recommend that or to get the TST and stack it with the EZ. That's the ultimate ticket...
I have the Edge EZ and it works fine for stacking. I have stacked with HOT Juice, BD Triple Dog and now TST.
If I had to do over though I would get the MP-8. You have much more granular adjustment and can basically turn it off with the switch. The EZ can not be turned off/set to stock with out removing.
Just my .02.
Just my .02.
The MP-8 is the new name for a TS Performance Ramifier. It is a fuel pressure box that does boost fooling...both negative and positive boost fooling to give it exceptional low end. It has infinite adjustability with a rotary ****. It is good for 100 hp by itself. I never use mine more than 50-60% in my stack with the TST Twins Program. It was renamed the MP-8 becuse you can purchase different wireing harnesses and have it reprogramed to work on multiple brands of diesel trucks...maybe tractors too!
pquestad
Mar 28, 2005 10:12 AM
joeservo
182
Jun 17, 2004 03:54 PM
Fummins
Mar 14, 2004 11:10 PM
