Edge EZ
Old 01-07-2007, 09:23 PM
T-REX's Avatar
Edge EZ
Will I need gauges if I run the Edge EZ, and will I burn my clutch out.
Old 01-07-2007, 09:26 PM
Thats MR Hoss to you buddy!
Hoss's Avatar
In my opinion, no, and probably not. I ran the EZ for around 30,000 miles without gauges and without any other problems.
Old 01-07-2007, 09:37 PM
973604x4's Avatar
EZ level 3....0-80mph on a stock turbo i was at 1500* on my EGT gauge.
it won't burn your clutch though
Old 01-07-2007, 11:35 PM
BigDave12768's Avatar
I just romped my truck down the highway on Extreme 100hp and the EGT's never went above 1050. But I ws empty and trying to configure the thing
Old 01-08-2007, 06:14 AM
Patrolman808's Avatar
I ran the EZ maxed out for about 9 months. Never had a problem with the clutch, just sheared the flywheel bolts off in the crank. Guess the stock clutch holds pretty good
Old 01-08-2007, 06:48 AM
Dodgezilla's Avatar
BigDave, those temps are a little low. I could hit 1200 degrees when my truck was stock. My Quad on the middle setting is probably close to an EZ on level 3 and I can easily hit 1400+ degrees on a hard pull......
Old 01-08-2007, 08:49 AM
Bikinaz's Avatar
I can easily hit 1350 degrees pulling my trailer on a grade on level 1. Uh, yeah I would get gauges.
Old 01-08-2007, 03:05 PM
I wish I had put my EGT probe in the manifold to see the readings there. I couldn't tell much with it after the turbo.
Old 01-08-2007, 03:23 PM
2broke2smoke's Avatar
the wifes '06 can hit 1350 emtpy at wot and thats with a gutted cat and mbrp cat back ...
the first mod anyone should do on an '06 should be a pyro...
jwhip
28
05-29-2005 11:32 AM
rockjeep73
03-25-2005 03:34 AM
Hoss
13
06-18-2004 06:14 PM
powerwagon440
01-20-2003 08:50 PM
Quick Reply: Edge EZ
