EDGE EZ Problem Has anyone's done this?????
Old 12-12-2004, 08:06 PM
reb0957's Avatar
Angry EDGE EZ Problem Has anyone's done this?????
Well, Truck ran fine last night. This morning went to start it and it wouldnt. It would just stumble for 3 or 4 seconds then die. Reset it to level 0 and did same thing.
I guess i am going to find out how good there customer service is!!!
Old 12-12-2004, 08:48 PM
GasMan's Avatar
Sounds like what happened to my truck when the lift pump died.
Old 12-12-2004, 10:18 PM
reb0957's Avatar
I hope NOT
GASMAN,
Did you have an EZ when the lift pump went out?
The truck ran absolutely fine with the EZ off the truck.
Old 12-13-2004, 04:19 AM
Dodgezilla's Avatar
reb0957, are you saying that the truck ran fine after you took the EZ off of it? I never had the problem you describe but I did have a "Poor idle" condition and when I called Edge they were very helpful and sent me a new box out right away. They will ask you to give a security deposit which you will get back as soon as they get your old unit back..... How long was the box on the truck?
Old 12-13-2004, 08:24 AM
Thats MR Hoss to you buddy!
Hoss's Avatar
Re: EDGE EZ Problem Has anyone's done this?????
I could be wrong, but I'm not sure that your EZ is the source of your problem. Kind of sounds like you're not getting fuel. Have you checked the fuel filter?
Old 12-13-2004, 08:27 AM
reb0957's Avatar
Dodgezilla,
I have had it on the truck since March. And yes as soon as I pulled the EZ off the truck ran fine.
That afternoon I set the EZ on O and reinstalled it. Same problem again. Truck ran real rough for 3 or 4 seconds and would die. Take off EZ and truck runs fine.
I guess i am going to find out about their customer service shortly. Mine is actually a Diessel Dynamics TTPM wich is a rebadged EZ. It even has an Edge tag on it. I e-mailed both last last night. Waiting to see who replies.
Old 12-13-2004, 09:29 AM
banshee's Avatar
Check the pins on all of your plugs very carefully. I had a rough idle problem one time that I tracked down to one of the MAP sensor pins wasn't seated right on the EZ. I guess it had popped out and wasn't contacting the wire correctly. I used a paperclip to shove it back in and to check all the others and the problem was fixed. Just a thought before you go through the trouble of shipping the box back....
John
Old 12-13-2004, 11:45 AM
reb0957's Avatar
Well, Edge called back first and I am on the way to ship it back to them. No questions asked just send that one back and we will send you an updated version. WOW!!! I didnt have the six levels anyway.
YEs, as soon as i removed the EZ the truck runs fine. The truck wouldnt run but 3 or 4 seconds just sputtering and dying. Remove the EZ and all is good put a hundred miles on it yesterday with foot all the way in it. ( had to put foot all the way in it) Anyways, it is amazing what a little box and 4 wires will do. i miss it badly already.
Old 12-13-2004, 04:39 PM
Dodgezilla's Avatar
You still won't have the 6 levels though. You will have 5 but number 5 is not advertised.......
Old 12-13-2004, 05:21 PM
Kyle Graham's Avatar
I would still check fuel pressure just for fun. Edge is awesome when it comes to customer service they completely back up their products at least from my expeirience's
Old 12-13-2004, 05:26 PM
crobtex's Avatar
Absolutly RIGHT on the Edge service.
HighTen
11-05-2005 10:04 AM
AAmeeting
24
09-18-2005 10:45 AM
John Rodriguez
01-12-2005 08:51 AM
Farmer
12-31-2003 06:54 AM
Quick Reply: EDGE EZ Problem Has anyone's done this?????
