Edge EZ died.... what to replace it with
Old 06-13-2010, 07:09 PM
Mechanos's Avatar
Last winter, my Edge EZ died. I unplugged it from the IP, but left it plugged into the MAP sensor to work as a boost fooler. Anyway, I'm missing the increased performance and need to replace it with something.
I would like to replace the HY35 with an HX35, but don't know what to replace the EZ with. Any suggestions?
Old 06-13-2010, 08:00 PM
Copenhagenjunkie's Avatar
Smarty, same hp as EZ with a code reader and Revo fine tuning.
BTW, I don't miss the humidity of the midwest. You from KC? Where did you go to high school, SMNW for me.
1882's Avatar
My vote goes to the Juice with Attitude
Old 06-13-2010, 08:05 PM
RowJ's Avatar
If you were happy with the extra power from the EZ, get a Smarty!
It is by far the best of the 60 HP programers. It daily drives like a lot more power... if you use #7 or #9 power lwvwl!
RJ
Old 06-13-2010, 09:36 PM
Mechanos's Avatar
If I get a Smarty, what should I use as a booster fooler? Keep using the EZ box... or is boost fooling part of the Smarty as well?
Old 06-13-2010, 10:08 PM
motochamp250's Avatar
if im not mistaken, the smarty does boost fooling on its own...
Old 06-14-2010, 07:11 AM
RowJ's Avatar
Smarty has boost fooler included!
You want the S-03 Model. See HERE
Smarty, with an HX-35 is a great combination! Add a set of Mach 1.6's and you'd have a sweet, very usable, 350 hp!
If on a tight budget... the Bosch RV275's would also be nice (+40 hp for around $300.00).......
and would probably still work OK with your HY-35.
I mention injectors only because, if your still running stock injectors, they are probable very tired.
RJ
Old 06-14-2010, 12:17 PM
Mechanos's Avatar
RJ
Thanks for the info. What about a set of DDP 50hp injectors? Do you think they would work ok with the HY-35? I've been wanting to swap it out for an HX-35, but $$$ has been tight with moving, 2 mortgages, etc. etc. Truck only has 154k on it.
Old 06-14-2010, 12:57 PM
RowJ's Avatar
Pronbable work OK.... but I would do the Bosch RV275's before I did the DPP's.
Assume they would be less $ and the two people I know that went from DPP's to F-1 Mach injectors noticed a BIG difference.
But guys that have only had DPP's seem to like them so.....?
RJ
Tingram
06-29-2010 11:22 PM
13ALPHA
07-08-2009 05:39 PM
blackrider
12-13-2006 08:56 PM
Tommy93w350
20
11-01-2005 11:07 PM
powerwagon440
01-20-2003 08:50 PM
Quick Reply: Edge EZ died.... what to replace it with
