Edge comp question
Edge comp question
I have a 2000 CTD. Do i need an edge comp specifically for the 2000CTD, or can i get any year comp and just find/make an adapter?
thanks a bunch
Ian
thanks a bunch
Ian
Ian, the harness the same for the 99-00's... 01-01.5 are the same.. and 2002... There are 3 different wiring harness.. What do you have.. and what are you needing, I might be able to help..
Bryan
Bryan
i'm looking for a used edge comp for my 2000CTD, so i'm not looking to break the bank. I don't care what year the comp is for, as long as I can hook it up to my truck in some way or another
hey ian,where in b.c. are ya from?im from vernon.i have a vanaaken plugnpower.im looking to get rid of.its not as powerful as a comp more like an ez.still a nice kick though.let me know if your interested.it says its for a 98-00 on the box but i used it on my 01 no problem.plugs directly on the ip.
You can buy the adaptor for the 98.5 - 00 Comp that lets you plug into the 00 harness if the used Comp you find does not have it. When you buy a new 98.5 - 00 Comp it comes wired with the connector to plug into the 98.5 - 99 MAP and includes the adaptor to plug into the 00. These guys are right, though.....you cannot use a 01 and later Comp as it is programmed to operate with a different MAP voltage and will not operate properly in a 00 and down CTD. You must get the 98.5 - 00 Comp.
hey, thanks guys, thats the info that I was looking for.
Duallydave - I'm from Maple Ridge in the lower mainland. how many hp/torque on the van aaken and how much would ya let go of it for?
Cheers,
Ian
Cheers,
Ian
lvmknsmoke..
08-13-2009 10:59 PM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
