Edge Comp Installation
I'm going to order my edge comp box tomorrow. My truck has 112,000 miles on it. I don't have guages yet either only one thing at a time. Should I expect any problems after installing the box? What should I expect out of the VP 44 any problems or pierce and pray? Its going to be about a month before I can get the guages any suggestion on running the box without guages?
Originally posted by duner
if it's going to take a month to get gauges, calculate the years it will take to buy a new engine.
you can run the comp just dont tow with it . ,your VP will die only if its already sick , Its a good idea to at least get a FP gauge. But then again if the pump is weak ? its gone anyways . these guys are pretty **** about there gauges. If your running around red light to red light you wont use the gauges anyways.
Ok I'll listen, Kinda, I ordered my guages today only ordered a pyro and boost guage. I also ordered the edge comp box. Correct me if I'm wrong but if the VP is going to go its going to go weather I have a guage or not. Not that I look forward to it going out. Mark at Diesel Performace Parts hooked me up with the best deal I could find. If anyone has any comments or suggestion lets here them everything should be in tomorrow and ready for hookup soon. Not to start a huge rock throwing match but what is everyone's thoughs on removing or leaving the turbo during installation? thanks Why should I not tow with the Edge Comp?
With your truck being a 2002, you should be looking at installing a Fuel Pressure guage. The lift (transfer) pumps are what gives up the ghost on the 24v trucks. If you only want 2 guages, get the pyro and fp guage, imo.
Casey
Casey
Casey
Casey
Since you have an '02, the pump should survive the Comp. Most of the VP failures from wire tapping were on the early 24V trucks ('98-'99)
Justin
Does anyone know if the Edge Comp box for an 01' would work on an 02'? The reason I ask is I have heard that the box through out the years is the same, but the connectors are different for each one.
