Easiest way to get oil in ur NV4500
Guys,
what is the easiest way? I like using those little siphon pumps with hoses on both ends, BUT they keep busting on me after the first or second use..
Does anyone know any other easier way?
Thanks guys!
Rick
Thanks guys!
Rick
I have a Mity-Vac, it swaped the tranny fluid for me, and flushed my brake system, and is holding up fine. I have the plastic one, but they also make a metal version.
http://www.mityvac.com/
time to get me one of them.... and bout the piece of hose? NO PATIENCE.. no yelling intended...
Rick
I buy my Syntorx in gallon jugs here http://www.standardtransmission.com/dodge.html
This $6 pump is designed for pumping thick anti-flat tire sealing gel, easily pumps even 90w and screws right on to the top of most all gallon jugs, does about half a cup per stroke. Been using the same pump for at least seven years on differentials, transfer cases and trannies.
http://www.gemplers.com/a/shop/produ...31520621102214
The hand transfer pumps from the autoparts are a pain to clean out and if you aren't watching out easily tip over the container you're pumping out of making an expensive mess.
APD
07-25-2014 10:38 AM
jmccart
20
10-30-2007 08:41 PM
Gman_dodge
09-06-2007 03:27 PM
Bookshelf
03-25-2007 09:12 AM
