Dynoed the truck
Old 01-14-2008, 05:43 AM
GFB
GFB's Avatar
Dynoed the truck
Run 1: Banks wire tap on, XZT+ timing/fuel
Run 2: No wire tap, XZT+ timing/fuel
Run 3: XZT+ timing only
XZT+ had the aggressive tune. I'm happy with the numbers.
Discuss.
Old 01-14-2008, 05:44 AM
GFB
GFB's Avatar
Also EGTs only hit 1250 and boost 38 on run 1. I wish it were that way on the road!
Old 01-14-2008, 06:05 AM
Ph4tty's Avatar
The graph could have been much prettier with smoothing turned up =p Thats great for what you have in the truck. Max torque by 1800 must be nice for the street
Old 01-14-2008, 07:24 AM
GFB
GFB's Avatar
Yeah, I enjoy the early spool and that's why I've swayed from a turbo upgrade thus far. I think twins are the only way I'd be satisfied but I need o-rings and studs first.
I think I might be close to an ideal mild setup as is. I can actually watch the EGTs drop from 1200 to 1100 when the turbo spools, but by then it's rocketing past 35psi on its way to 40+, then the pyro needle direction changes back the other way until I let off the throttle. Maybe if I could play with the wastegate to keep the boost at 38 I could keep the EGTs in check. I'm sure some work with a die grinder on the manifold and turbine housing wouldn't hurt either.
Old 01-14-2008, 08:42 AM
Ph4tty's Avatar
Put a cam and some studs in and you're done. Lower boost, lower egts, and quicker spool. Unless you want to go crazy
Old 01-14-2008, 08:49 AM
haloman's Avatar
Sweet numbers.
Old 01-14-2008, 09:18 AM
RowJ's Avatar
Yup! Well done! Nice results for what you have.
Something like a PS62/14 (if not going higher on HP) would spool as fast, run cooler, smooth out the graph and add 30 HP!
I think your still overfueled. JMO.
RJ
BigJohnston
24
12-27-2007 02:22 PM
PourinDiesel
69
08-29-2007 10:45 AM
VikingDiesel
19
04-23-2007 03:22 AM
goodeyesniper75
16
08-14-2006 04:58 AM
Quick Reply: Dynoed the truck
