PDA
View Full Version : Dyno this Saturday, what settings should I run?
J Lent
11-17-2008, 10:47 PM
My plans are:
1. Adrenaline for the first run using my favorite custom tuning settings.
Fuel Stretch 2200
Timing 10*
Pump max 100
Pump min 0
Can max 100
can min 0
Boost scaling 20
2. The second run will be Redline/Smarty.....What settings?
3. If time allows, I want Redline/Adrenaline stack as 3rd run.
I'm not sure if time will allow me to change the Smarty setting between runs, but I'm hoping for this! Also, what gear should be used in my nv4500?
Big Blue24
11-17-2008, 11:03 PM
You should dyno in 4th gear or 1:1 ratio in the tranny. If you can't build sufficient boost, have them ride the brakes a little or try 5th gear.
If I were you, I'd BS the dyno operator a bit about letting you do a few more runs. I'd try turning the fuel stretch down to 1600 and running PL 7 or 8. I'll bet you make more peak HP on that setting than your favorite settings although your favorite will most likely make more area under the curve=more average HP.
You might try your favorite sled pulling tune as well to see how much HP you're making pulling 32-3600 rpm down the track!
J Lent
11-17-2008, 11:07 PM
Wierd thing is, my truck feels weak at anything below 1800 [fuel stretch]. Quad has stated that 1800 gives best numbers on his dyno, but my truck feels like it doubles power from 1800-2200. I'm lost?
Big Blue24
11-18-2008, 12:58 AM
You may have a freak of a pump that loves fuel stretch. Personally would try more than one Adrenaline setting as it seems some of the higher HP trucks found another 20-30 HP by tweaking things one way or the other just on different PL's. I know you want back to back Adrenaline vs Redline but it will be difficult to get both tuned-in with just 3 total run. It probably wont matter which settings you run, I think the Adrenaline is going to make more HP further into the high RPM's.
Ph4tty
11-18-2008, 03:31 PM
Direct drive for load dynos and overdrive for dynojets. The settings that feel the best on the street may very well not make more power on the dyno. Its probably making more power up to a certain rpm with the lower fuel stretch, but the peak is a little higher and later with the less stretch giving the higher hp number. Remember that hp is just a function of torque and its relation to rpm so the later the peak the higher the number. Also remember that those new valve springs will cost power, but the sticks ought to make up the difference and then some =P
J Lent
11-18-2008, 04:24 PM
My main concern is seeing where my truck makes power for the sled pulls. I am not too worried about posting big numbers, just want to see how the 2 boxes fuel. I posted about the Adrenaline pulling over 4k on the street & I got laughed at. I can't feel the power drop off & I want to know if I'm atleast making 200hp at 4k. That is my main concern, the rest of the reason is to keep my promise to the guys on here. I told everyone that I would dyno if I could find one & I'm a man of my word.
J Lent
11-18-2008, 04:27 PM
I'm not sure if the guy who owns the dyno will do the runs or if he will let us run them. I have never been on a dyno myself, not sure how to do it? If I do get to run it myself, Is this how its done? Get to steady speed of about 20-30mph through 5th gear, then hammer down?
gotslicks
11-18-2008, 05:58 PM
usually denis runs the truck and as you said gets it into 5th at low speed and lets it fly.
4th dosent work out so well on the dyno
gotslicks
11-18-2008, 06:00 PM
anybody who is in the area is welcome to come join us in latrobe pa at the dyno.
just get ahold of me for info and directions
it is a dynojet and has just been upgraded to read up to 2000ftlbs and 200 mph
J Lent
11-18-2008, 06:55 PM
Good! They'll need that upgrade when I get on there.[laugh][duhhh]My brother is coming down too. Think his dually will fit?
gotslicks
11-18-2008, 10:06 PM
if it dont we can take the outside wheels off and run it
guarenteed to fit then
J Lent
11-18-2008, 10:29 PM
That works for me. Do you know if he will allow us to change Smarty settings between runs? I will also need to switch my pump tap from ADR to redline [quick tap, spade terminals].
J Lent
11-21-2008, 07:17 PM
Tomorrow is the day guys & I am ready to roll. Last time I dynoed was 476/936. Totally different setup & I'm hoping to break 500 this time. Any guesstimates before the big day?
01smoker
11-21-2008, 07:47 PM
I'd say you're gonna be around 515 rwhp. Thats my guess.
gotslicks
11-21-2008, 08:10 PM
i basically have free range of the place
just get a plan together so he knows what you want to do on the dyno
J Lent
11-21-2008, 09:44 PM
Will do. I'll pay more if needed, but I'd like to get as many runs as possible.
95ram
11-22-2008, 04:06 AM
What setup did you dyno before? What dyno? If its your current injectors/turbo etc. You numbers seem a little low. I did 460 on similar(DDP) injectors and smarty alone.
J Lent
11-22-2008, 05:17 AM
Completely different setup. I had Dragon fly injectors, edge comp & 62/65/12 with 40psi boost & holley blue pump. That was on Dave Dunbars dynojet. 476hp/936lbft.
smokin24v
11-22-2008, 03:23 PM
just wonderin how your stackin the redline and the ADR together??? sounds like that would be pry wicked??? can't wait to see how u do good luck
