Dying Clutch Fan?
Old 03-06-2011, 04:55 PM
johndeer's Avatar
Dying Clutch Fan?
I have light oil dripping under the engine front, it's also sprayed around the front under-hood. I've twice had a momentary grinding sound like a failing bearing. I'm thinking its either the clutch fan or the water pump?
Thanks in advance for any advice. I'll be towing the 5'er home to Montana next week.
Rick
Old 03-06-2011, 05:20 PM
Hvytrkmech's Avatar
Grab the fan and inspect it for play and freedom of movement. You should have some resistance when trying to spin it, however it should be a fluid type resistance with no hard or soft spots. If there is any play in the bearings then it is junk.
Old 03-06-2011, 11:53 PM
johndeer's Avatar
Tim, I appreciate your advice and will do that in the am.
Rick
FamilyDiesel
03-30-2008 05:53 AM
jrs_dodge_diesel
09-28-2007 11:38 AM
MmmDieselFumes
09-27-2007 06:44 PM
MmmDieselFumes
09-27-2007 03:04 PM
big jimmy
07-07-2006 01:33 PM
Quick Reply: Dying Clutch Fan?
