duramax cp3 on a dodge
Old 01-26-2008, 07:13 AM
Dwitt0187's Avatar
Question duramax cp3 on a dodge
i called ii the other day and they said that the stage3 pump was just a modded cp3 from a duramax. i can get a new stock cp3 for a duramax from where i work for like $500 will it pump more fuel than a dodge pump or does it need to be modded to fit the truck. i can buy a stock pump from work for 650. i gues the main question is will the stock duramax cp3 pump more fuel than a stock cummins cp3 and will it fit without modifing
Old 01-26-2008, 07:43 AM
Bswope's Avatar
Not sure i can answer that but if u can get a D-max cp3 for that price why not just get it and buy a twin cp3 kit without the pump and run duals? U could check with Imills at http://www.midatlanticdiesel.com!
Old 01-26-2008, 07:45 AM
Dwitt0187's Avatar
i didnt think about that would the 2 pumps work together
Old 01-26-2008, 07:52 AM
Bswope's Avatar
Sure would bud! Most of the dual cp3 kits use a Dmax pump for the second pump, u would just need to buy a kit that has all the fittings and brackets needed! Check out that link and look at the Evil Twin CP3 kit!! Lloyd is a great guy to talk to also.
Old 01-26-2008, 08:00 AM
Dwitt0187's Avatar
thanks for the insight im going to look in to that
i would still like to know it the duramax cp3 will fit a cummins without modifing
Old 01-26-2008, 08:49 AM
Dwitt0187's Avatar
who here is running a stg3 cp3 from ii
Old 01-26-2008, 08:12 PM
Dwitt0187's Avatar
any info tonight on this question there wasnt many people on this morning when i first posted it
Old 01-26-2008, 08:23 PM
skynyrd's Avatar
i would like to know about this as well but you might have to ask this question over on competition diesel where you have D-max guys as well as cummins and PS guys.
Old 01-26-2008, 08:27 PM
Dwitt0187's Avatar
is that another website or a differant forum on this site?
Old 01-26-2008, 08:35 PM
skynyrd's Avatar
its another website kinda setup like DTR they are a little more geared to the competition side of things. www.competitiondiesel.com i would say one of the chevy guys over there could let you know about the D-max cp3 pumps
Old 01-27-2008, 08:19 AM
rustyshakelford's Avatar
the d-max pump isnt a direct replacement. the fittings are different and there are a few other differences
brett
Old 10-14-2012, 06:59 PM
DWat9421's Avatar
True, the d-max pump is not a direct replacement but it can easily be modded to fit on a common rail in place of your stock dodge cp3. a stock duramax pump is a Cummins stage 2 CP3. and can support up to 500HP on a cummins easily.
Old 10-14-2012, 09:34 PM
rockcrawler304's Avatar
Now that is digging up an old thread!
But at least you added to it with good info.
rogers259
01-15-2009 12:35 AM
wap
27
09-03-2008 02:10 PM
pullin hard
03-18-2008 03:57 PM
megacabrule
33
05-10-2007 01:07 PM
rich2500
01-21-2006 12:52 AM
Quick Reply: duramax cp3 on a dodge
