Dually Tire Valve Stems?
Old 10-07-2004, 07:32 AM
Sidewinder's Avatar
Question Dually Tire Valve Stems?
I am about to buy some new tires for the dually. What's the best setup for the valve stems for the rear duals or all of the the wheels? Right now it just has regular short rubber valve stems and it makes checking/filling the inside tires a pain. I have seen some extensions but I don't know how well they would work.
Anyone got a better system?
Old 10-07-2004, 08:20 AM
Muted User
scarecrow's Avatar
i dont know who makes em. i had em my old dually. i got mine from the local big rig shop.
Old 10-07-2004, 08:31 AM
pappyman's Avatar
Metal valve stems work best they don't bend when your checking pressure.....I use a straight air chuck to check and fill my inter tires it goes thru the hand holes better.....be careful of cheap plastic extention they can leak
Old 10-07-2004, 09:16 AM
zulusafari's Avatar
I have the plated brass clamp in type valve stems. They are short, but stiff! The double headed truck style airchuck works great, fits through the handholes, and pulls toward you for the front wheel, pushes away for the inside wheel. The rubber bushing for the rim hole seals very well. I bought mine at the local farm supply store, for about $2.00 each.
Old 10-07-2004, 10:47 AM
TPilaske's Avatar
I had Steel Valve stems put in all 6 tires (for rotation purposes) I got braided stainless extenders from Camping World that work great!
Must have been a rocket scientist who designed the valve stems to face inward on the dually....
Tony
Old 10-07-2004, 01:11 PM
zulusafari's Avatar
You kind of answer your own statement. Rotational purposes. Only two of the 6 wheels have the stems facing in. When rotated, they face out again in the other positions.
Old 10-07-2004, 01:16 PM
TPilaske's Avatar
Maybe they should just come w/ extenders then!
Old 05-23-2005, 03:47 PM
Haulin_in_Dixie's Avatar
Go to any shop that repairs big truck tires and get them. Get brass stems at least 1 1/2 inchs long so that they are not too close to the wheel to get the air chuck on. That way you won't need extensions.
Old 05-23-2005, 04:07 PM
Thats MR Hoss to you buddy!
Hoss's Avatar
And welcome to DTR!!!!
Just out of curiosity, Tireman, you ARE Chuck....are you not??
Old 05-23-2005, 05:16 PM
Administrator / Scooter Bum
Shovelhead's Avatar
And when you rotate your tires, you move the valve stems?
80,000 miles and I've always been able to check pressures and keep them aired up.
It might be worth it for a physically impaired or non-mechanically inclined driver.
Just not for me.
Old 05-23-2005, 11:08 PM
tireman11111's Avatar
First I asked the moderator to delete the two messages, then I discovered I could remove them myself.
Yes, Chuck does own a Ford and one of the kits is for Ford's. Only because we were told about the site today and that it would be a great idea to post the info about the kit for Dodge's did I post a message.
When I say Chuck is a wealth of info., if it's a customer at the counter or one that calls and does not buy from us he gladly tries to help anyone that asks. He is a salesman and not an order taker. At our store we treat people the way we like to be treated.
Sue @ Tire Man
Old 05-24-2005, 08:13 AM
59FORD's Avatar
I see there has been a lot of editing going on ...... and I missed it.
DURN
Everything I saw is FREE at my tire shop when you buy tires.
I just tell them which stems I want...NO CHARGE! never has been.
$0.05 ............... I don't have any change this morning
Old 05-24-2005, 09:42 PM
Hoss's Avatar
Come on fellas....lighten up on Sue. We could always use a couple of nice ladies around here to keep you scallywags in line.
Old 10-27-2006, 12:15 PM
Thumbs up stems
do a search on yahoo under tire-man, for all 6 wheels, kit #3-6
Old 10-27-2006, 03:20 PM
Shovelhead's Avatar
From May 2005........talk about a blast from the past..............
Quick Reply: Dually Tire Valve Stems?
