dually fender
Old 10-14-2009, 09:56 AM
olddodgetrucks's Avatar
dually fender
what is the best product to use to repair a crack in 99 dually fender
Old 10-14-2009, 10:00 AM
Pickin on the wrong admin...
Diesel Dave2's Avatar
I don't if this is the right way or the best way.I had a couple of tears also.I fiberglassed the tear from the back and it seems to be ok so far.
Old 10-14-2009, 12:50 PM
Dinner's Avatar
I was going to suggest fiberglass as well. Just make sure to grind area free of paint and v the crack. Make up your fiberglass and resin how ever you prefer and apply. Once tried and sanded it should be good! Could also do the inside of the crack too if you really wanted to, but that is a bit more work.
Old 10-14-2009, 01:33 PM
91r/t's Avatar
drill both ends of the crack as well to stop the crack from spreading.
Old 10-14-2009, 01:48 PM
Load Hauler 04's Avatar
Make sure you glass it inside and out or it will crack back thru...
Eddy Reyes
32
06-05-2007 07:36 PM
Fisherguy
04-13-2006 09:17 PM
sherod
02-18-2005 04:28 PM
danram
05-23-2003 05:15 AM
danram
05-12-2003 03:45 PM
Quick Reply: dually fender
