View Full Version : Dually Fender Light Flicker
rebel_horseman
01-16-2011, 08:42 AM
FOr the past month or so I've noticed that one of my marker lights is flickering and/or won't come on at all. Last night I tinkered with it and it looks like the rubber connector that attaches to the light has a bad connection.
Is there a source for these connectors?
ghenges
01-16-2011, 09:26 AM
The clearance light (if the same as a 1992 dually) is a model 19 type light.
http://www.truck-lite.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=33153&langId=-1
Other manufacturers offer the same design.
I our area Napa stocks these lamps and socket bases.
rebel_horseman
01-16-2011, 06:03 PM
I've seen those as well, but the problem is the 2-hole connector is what I need. All the ones that I've seen have had one power wire to the connector with a piece of copper to go to ground when you screw the mounting bolts in. I guess I could retrofit it.
